Help
Old Jul 20, 2011 | 04:01 PM
millz's Avatar
Default Help
So i bought a coupe and found out more problems with them car. Any help on what i can do?
Engine Bay
Bad cut under, you really don't wanna see
Floor Panel Bump
Floor Panel Bump 2
Old Jul 20, 2011 | 06:32 PM
SovXietday's Avatar
Default Re: Help
That car is ****ed. Royally. Even after a long time on a frame straightening rack I don't see that car ever being straight again.
Old Jul 20, 2011 | 08:09 PM
moxynoff111's Avatar
Default Re: Help
Its hard to tell from the pictures what components are damaged. There might be enough adjustment in the suspension components to get it driving straight. You should really plan on fixing all the damage. There is always the possibility of the damage causing excessive wear and breaking causing the driver to lose control the vehicle.
Old Jul 20, 2011 | 08:11 PM
k24em2's Avatar
Default Re: Help
I hope you didn't pay very much for it.
Old Jul 21, 2011 | 02:11 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Help
the junkyard is the only place that thing should go
Old Jul 21, 2011 | 06:59 PM
millz's Avatar
Default Re: Help
The frame isnt really bad, just the front was behind the headlights was damaged and there was about a 4 inch rust hole through and through
Frame wise is straight i just need the holes filled and radiator support fixed
paid 300 for it basically
i got the radiator support coming in this weekend, i wanted the front frame rust hole covered and the shifter hole that was covered neated up
Old Jul 21, 2011 | 07:14 PM
k24em2's Avatar
Default Re: Help
Dude it's probably worth more than 300 as scrap right now
Old Jul 22, 2011 | 07:32 AM
SovXietday's Avatar
Default Re: Help
Then why are the front floors so distorted? That's what's making me thing there's a lot more damage than what you're aware of.
Old Aug 3, 2011 | 08:50 PM
millz's Avatar
Default Re: Help
floor panels i fixed, engine bay area behind drive headlight fixed, now i just need the big cut holes covered
Old Aug 4, 2011 | 10:03 AM
SQ is the SQUAD's Avatar
Default Re: Help
you need better pictures of the hole area. the floors just looks like someone jacked it in the wrong place. what year a model is the car?
Vtec04
Jul 9, 2017 11:56 AM
xtremegsr273
Aug 26, 2005 09:22 AM
E dwinbon G
Jan 11, 2003 02:26 AM
