Plug and Play O2 Simulator solution
Old Jul 19, 2011 | 03:46 PM
KraZyCHOWMEIN's Avatar
Default Plug and Play O2 Simulator solution
I searched and all signs pointed to Black R from 2007 through about 2009. It looks like he had a plug and play solution for an o2 simulator. I PM'd him a couple days ago but not sure if he's still active on the board. Google/Bing searches haven't provided a viable solution. Spark plug fouler won't work because I do not have a secondary bung on my exhaust.
Anyone have one that Black R made for sale or a better solution that doesn't cost $99 bucks.
Thanks
Old Jul 19, 2011 | 06:26 PM
highroller54's Avatar
Default Re: Plug and Play O2 Simulator solution
Hes still around I think, he was trying to sell me his wheels not that long ago.
Old Jul 19, 2011 | 08:13 PM
Tooburns's Avatar
need that solution too
Old Jul 20, 2011 | 02:41 PM
00-1065's Avatar
Waiting for the replies....
Old Jul 20, 2011 | 03:05 PM
Black R where are you!
Old Jul 29, 2011 | 08:24 PM
Tooburns's Avatar
still no news ? ?
Old Aug 4, 2011 | 08:12 AM
acuratsx228's Avatar
cant you just drill and thread a piece in the exhaust pipe and and use a O2 simulator.
Old Aug 4, 2011 | 09:47 AM
PaulMc's Avatar
Painfully Stupid
I used this. Payed about $99 for it and it worked, for about two weeks, but long enough to get me through inspection. I couldn't figure out how to tweake the simulator, it was kind of a piece of ****. But I'm sure they're are better one out there that actually work and don't get hot like the one I had.
Old Aug 4, 2011 | 11:15 AM
94rs-turbo's Avatar
I need a 2nd o2 sim as well
Old Aug 4, 2011 | 12:03 PM
this way i used, i only had ut on for a couple of days, so dont know if it works that great or not.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Old Aug 4, 2011 | 09:30 PM
Thanks for the research but I don't think this is any different than a spark plug fouler. I don't have a secondary bung on my setup
Old Aug 5, 2011 | 05:40 AM
R134's Avatar
I would just put a bung in. I had the simulator, I made it using the plans posted many years ago that i think black r uses. Mine worked for 1 or 2 years. I now use a spark plug defouler.
Old Aug 5, 2011 | 06:24 AM
Todd00's Avatar
I said I don't want a title!
Problem with the Spark plug defouler is that it sometimes puts the O2 out too far and it'll hit the chassis. Just depends upon the cat/testpipe that you're working with.
Old Aug 5, 2011 | 08:14 AM
R134's Avatar
Here are the plans that used to be floating around years ago. I re-labeled the wires because the plans were for a different car originally.
This is what it looks like when made. Worked great until I plowed through a snow/ice drift and broke it. It was under the car wrapped in plastic, ziptied to something... forget now.
Pay no attention to the wire colors, those are extension wires from running a long tube header.
Old Aug 5, 2011 | 01:43 PM
Sweeeet thank you!
Keep all posted as to how it goes.
Old Dec 18, 2012 | 06:25 AM
lsv-1's Avatar
Hello guys, by any chance do you know if this would work on a Honda Civic 2002 vtec? This trick shuts the CEL off for good? Does it work even if you remove the cat or install a non OEM cat? Thank you.
Old Dec 19, 2012 | 02:49 PM
azteggy_g2's Avatar
bought this one and worked fine. Not plug n play though. Have to do a bit of wiring, but it wasn't too bad
http://www.ubertechnics.com/O2_Simulator_2.5.aspx
used this diagram
https://honda-tech.com/forums/hybrid-engine-swaps-18/how-i-bypassed-my-knock-secondary-o2-ckf-sensors-my-96-dx-hatch-2990959/
but mine was OBD2b so I had to translate the wires accordingly using
http://technet.ff-squad.com/wiring.obd2b.htm
Old Dec 30, 2012 | 07:53 PM
Finland's Avatar
excellent thread.
redline32
Engine Management and Tuning
May 28, 2009 07:54 PM
ExVtec
Honda S2000
Apr 18, 2009 09:34 PM
phiberoptik
Jun 8, 2004 12:43 PM
twuelfing
Nov 21, 2003 04:59 AM
souk
Dec 30, 2002 06:11 AM
