O2 Simulator
Old Nov 19, 2003 | 04:56 PM
twuelfing's Avatar
Default oxygen sensor connectors
does anyone know where to get these plugs?
i tried the caspers O2 simulator and it did not work and there was no email responses for weeks now i am onto try 2 with this one:
<A HREF="http://www.importparts.com/importparts.storefront/3fbc20df0004c854271d424d361a05ea/Product/View/ECG-28/
" TARGET="_blank">http://www.importparts.com/imp...28/
</A>
however it doesnt look like it can plug in and i would like to make it just plug into the harness if possible.
please help if you can.
Old Nov 20, 2003 | 03:38 AM
twuelfing's Avatar
Default Re: oxygen sensor connectors (twuelfing)
no one? wow, well when i get the new one i will post here if it works or not.
Old Nov 20, 2003 | 04:54 AM
davidnyc's Avatar
I have a test pipe without an O2 hole. So, I just pulled the secondary O2 sensor into the passenger compartment, wrapped it in aluminum foil and electrical tape and no CEL.
Old Nov 20, 2003 | 12:53 PM
twuelfing's Avatar
what does the aluminium foil do?
i pulled mine into the cab and i get the check engine light after like 30 miles.
Old Nov 20, 2003 | 01:40 PM
jdmspoonitr's Avatar
Default Re: (twuelfing)
Don't pull it into the cabin. You have to leave it plugged in, but remove it from the cat. Then strap it with foil around the shifter stabilizer. The foil prevents the hot exhaust from melting the wires on the sensor. No need for simulator. No CEL in over one year.
Old Nov 20, 2003 | 04:03 PM
twuelfing's Avatar
its still plugged it its just behind the dash now. how would that differ from being underneeth the car
Old Nov 20, 2003 | 06:52 PM
I don't know, but everyone I know that has done it my way hasn't had a CEL. Just give it a try for a week. It wouldn't be as bad as not trying it and finding out it actually works.
Old Nov 20, 2003 | 07:45 PM
davidnyc's Avatar
Default Re: (jdmspoonitr)
I don't have a hole in my test pipe so I had to pull the O2 into the cabin or connect it to something underneath the car. So, I decided to pull it into the cabin. I have absolutely no idea of the purpose of the aluminum foil, but I know others did it, so I did it also and have no problems.
Old Nov 20, 2003 | 07:54 PM
Smitdog's Avatar
Default Re: (davidnyc)
JDM ITR Ecu here... does not read 2nd 02 among some other things.. therefore i unclipped mine and store it!
Old Nov 20, 2003 | 08:45 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twuelfing &raquo;</TD></TR><TR><TD CLASS="quote">what does the aluminium foil do?
i pulled mine into the cab and i get the check engine light after like 30 miles.</TD></TR></TABLE>
.....what code are you throwing?
Old Nov 21, 2003 | 04:57 AM
BudMan's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
.....what code are you throwing?</TD></TR></TABLE>
I'm sure it's probably 67 - which doesn't hurt the car, but it's a code that means you're not running an "efficient" cat. The cpu won't register the code until it sees the signal 3 times according to the helms. My Random Technology Cat has been replaced under warranty 4 times because it starts throwing that code within 6 months from new - about every 30 miles.
**I'm going to try the plug & wrap method!**
Old Nov 21, 2003 | 04:59 AM
BudMan's Avatar
Default Re: (BudMan)
Anyone happen to know the bolt size to use for the plug?
rsangha13
Mar 31, 2013 07:18 AM
Crider4_6
Engine Management and Tuning
Nov 14, 2011 04:26 AM
ELE0MENT
Nov 26, 2008 06:16 AM
LSReborn
Apr 29, 2007 07:45 PM
732xghost
Mar 27, 2007 11:21 AM
