Is power steering really important
Old Jul 12, 2011 | 09:07 PM
4DoorBanger's Avatar
Icon2 Is power steering really important
the other day i was getting my oil changed and the Mech. told me that it's necessary to have the power steering to lube some **** up, so it won't dry up. was he just trying to add on sales or what ?
p.s i have the power steering on just not the belt.
appreciate it
Old Jul 12, 2011 | 09:36 PM
thelaoskid's Avatar
Default Re: Is power steering really important
another words is it save to run the p.s without the belt
Old Jul 12, 2011 | 10:15 PM
Linked's Avatar
i've ran without a belt for a good while on my setup, so long as the fluid reservoir was topped off
this is similar to the loop power steering racks everyone does, they just remove all the uneeded parts and retain fluid in the rack
Old Jul 12, 2011 | 10:29 PM
pretty much my bad i always tend to say **** complicated lol
Old Jul 12, 2011 | 10:30 PM
for sure, i'll make sure on that
Old Jul 12, 2011 | 10:39 PM
CivicBlacksheep's Avatar
10 Year Member
Power steering fluid is to lubricate pump and gears....guessing u should always have tht topped off...the belt off isnt a big deal ^1+
Old Jul 12, 2011 | 10:40 PM
DO/\/\O's Avatar
Just remove the whole ps... didnt help for me
Old Jul 13, 2011 | 12:08 AM
Nooch's Avatar
Ya your title sounded retarded :]
Easy fix, remove belt as stated.
Old Jul 13, 2011 | 03:04 AM
Libertariat's Avatar
Ek Forever y0!
The best bet is to get an electronically operated power steering pump from an MR2, for example, and mount it and run your power steering fluid that way as an electrical accessory instead of a belt driven accessory.
Power steering can be very handy when you're spinning around on the track and would like to correct it. Without power steering it's very difficult to do this well.
Old Jul 13, 2011 | 07:19 AM
DSMAddicted's Avatar
Originally Posted by ek forever guy
The best bet is to get an electronically operated power steering pump from an MR@, for example, and mount it and run your power steering fluid that way as an electrical accessory instead of a belt driven accessory.
I know with enough money anything is possible... but I am assuming this is a 'reasonable and common' upgrade for Civics that already have power steering, correct?
Old Jul 13, 2011 | 07:39 AM
hyperblu's Avatar
The cx hatchback ill be getting in a few days came without power steering... The difference is day and night between a disabled p/s system and one that didnt come with it in the first place. It's a lot easier to turn than one with a looped rack or pulled belt...
Old Jul 13, 2011 | 07:42 AM
Ek Forever y0!
A guy in the autocross forum posted up a "tutorial" on fitting a Toyota MR2 electronic a/c pump into his civic and just ran it off of the fuse box. Just have to get the a/c lines to the pump.
Old Jul 13, 2011 | 07:43 AM
Ek Forever y0!
A looped rack is also harder to turn because power steering racks are typically closer ratios since you have the assistance from the power steering pump. So even if properly converted it's just going to be more difficult as the gearing is shorter. I.e. less leverage.
Old Jul 13, 2011 | 07:48 AM
hyperblu's Avatar
^^ exactly... alot less fight with the wheel when you're not moving..
Old Jul 13, 2011 | 07:51 AM
Ek Forever y0!
I'll deal with a looped system for a while after I get my swap done, but I plan on finding an electronic pump and running that.
h2b w/ac and power steering. Gangster.
Old Jul 13, 2011 | 07:55 AM
hyperblu's Avatar
Alot of H series swaps dont have a/c or p/s lol... You'll be the fortunate few. lol.
Old Jul 13, 2011 | 08:04 AM
Ek Forever y0!
A lot of them willingly don't have a/c, the stock h22 in a prelude runs a/c and the alternator on a serpentine belt, so frame-rail clearance is not an issue. It's just a matter of mounting it up like it comes from the factory.
Power steering is a different story since it is typically ran on a separate accessory belt that occupies precious frame-rail clearance.
Old Jul 13, 2011 | 11:13 AM
aznfreakyguy's Avatar
i couldn't find a cheap mr2 powersteering pump so right now my h2b setup is running the stock ls power steering pump its inline with the crank and alternator
Old Jul 13, 2011 | 01:20 PM
Ek Forever y0!
92LXcb7
Mar 14, 2012 08:57 AM
EK_MaGz88
Mar 20, 2011 09:29 AM
16yroldekownr
Jul 4, 2008 06:28 PM
busyychild
Feb 22, 2008 02:30 PM
PokePride
Apr 17, 2005 02:12 PM
