98 Civic Sedan speedometer issue.
So I have a 98 civic sedan and speedometer just doesn't work at the moment. I checked fuse 15 under the dash, which I replaced it with another 7.5 fuse because there was no power going to it when I tested it, and it had power again but speedometer still did not work. It doesn't move or anything. I'm not sure if it could be the speed sensor or what. Oh and the battery light on the cluster stays on as well. Lately the car has been dying when I leave it sitting for about 3-4 days or so. Any advice?
Re: 98 Civic Sedan speedometer issue.
I would test the battery, only 2 years old but you never know. I have heard mixed reviews about Optima's.
If you get the car started, after checking the battery check the continous voltage when running should be like 14.1 or so, 12 volts with key on.
If you turn the key does the Cel light go and on and then off, as the car goes through its start up mode?
Andy Van Sloun
17
12-15-2015 08:29 AM
88hondaspeed
06-14-2011 09:34 AM
