Cam Installation??
Old Jul 11, 2011 | 02:51 PM
journeyquest's Avatar
Default Cam Installation??
When putting a new head on my d15 do i lube the cam with assembly lube or oil or what? Thanks
Old Jul 11, 2011 | 03:32 PM
Grnnt4's Avatar
Default Re: Cam Installation??
Assembly lube, especially if it's a used cam.
Old Jul 11, 2011 | 03:43 PM
1990edsedan's Avatar
Are you saying that your are installing a head with the cam installed, or installing a cam in a head?
Old Jul 11, 2011 | 05:16 PM
I bought a rebuilt d15 non VTEC head that came with a cam and rockers. The old head was cracked. The new head came from a Del Sol. My car is a 90 CRX DX with d15. Not sure if the cams are the same so i will put the old cam in the new head. My engine only has 90k miles so i think the old cam should be ok. This will be the first timing belt change also.
Old Jul 11, 2011 | 05:20 PM
And you will do the waterpump and the tensioner pulley at the same time - right?
As to the head, was it off a d15b7, if it was, then I would not bother swapping cams, as they are very close. But, you will have to use the timing belt that belongs to that head.
Old Jul 11, 2011 | 10:58 PM
Ya, i have water pump and tensioner too. And will use the old cam pulley. The head is the same as the last one, but wasnt sure about the cam specs?
MikeD21
Jan 26, 2019 09:17 PM
toxictom
Engine Machining & Assembly
May 25, 2017 06:04 PM
chrisc543
Apr 13, 2016 06:57 PM
new_climber
Jan 16, 2009 05:27 AM
tyler
Sep 6, 2002 06:25 PM
