coolant coming out from reservoir tank
Old Jul 8, 2011 | 09:02 AM
delsolo95's Avatar
Icon2 coolant coming out from reservoir tank
hello peeps i have a 95 del sol with a 95 gsr. im having a minor problem with coolant coming out of the reservoir tank. my car idles perfect, thermostat is opening, and fan is kicking in.
the thing is when i drive to work (20 miles) with ac on, coolant will shoot out. not alot but id say about 4-6 fluid oz. i will only see it when i get home from work and there will be a small puddle where the reservoir tank is..how do i know? well i checked for leaks and nothing from top hose and bottom hose. there is evidence of coolant from the cap of the reservoir bottle.
i also noticed that my radiator cap looks different. there would usually be some plastic piece at the bottom of the cap but its missing. i will provide pics later today.
the car does not overheat im just curious to why coolant is shooting out
let me know what you guys think.
Old Jul 8, 2011 | 09:15 AM
delsolo95's Avatar
Default Re: coolant coming out from reservoir tank
my reserve tank im using off an 97 Ls integra
my cap
Old Jul 8, 2011 | 09:16 AM
delsolo95's Avatar
im guessing i need a new rad cap.. can anyone confirm?
Old Jul 8, 2011 | 09:32 AM
Gustav129's Avatar
I'd do a pressure test on the cap and system before replacing any part.
But a cap is a $15 part, if you want to throw parts at it.
Old Jul 8, 2011 | 09:45 AM
CFiannotti's Avatar
Buy a new OEM cap. I had one fail like that.
Old Jul 8, 2011 | 09:57 AM
delsolo95's Avatar
i guess i will replace the cap. i will keep you guys updated in a week or so
Old Jul 8, 2011 | 10:24 AM
HondaPartsHero's Avatar
Technical Hero
Yeah you're missing the most important parts: the spring and gasket. Might want to find that as well in the radiator. My accord did this last month as well.
Old Jul 8, 2011 | 10:55 AM
delsolo95's Avatar
so replacing the rad cap will eliminate the coolant shooting out of my reservoir tank cap?
Old Jul 8, 2011 | 11:14 AM
thenext's Avatar
20% cooler
You sure it isn't from your A/C being on? I have seen 4-6oz of liquid under a car from condensation dripping off the compressor. Make sure it is coolant.
Old Jul 8, 2011 | 12:07 PM
delsolo95's Avatar
yes im sure its coolant unless ac liquid is green too. when standing in front its coming from the left side of vehicle..the opposite of the ac compressor + its green..
Old Jul 8, 2011 | 01:06 PM
Gustav129's Avatar
Oops didn't see that. No need to pressure test it. Ignore my post above.
Yeah, you might want to find the spring and gasket or they might end up clogging the radiator and cause future overheating problems.
Old Jul 8, 2011 | 04:39 PM
motegicivic's Avatar
Was that a honda cap.........it looks shot. Cheap insurance get the cap, it pressurizes the system correctly.
Old Aug 22, 2011 | 08:43 AM
delsolo95's Avatar
i bought a new cap and it still shot out coolant. i guess cuz the spring and stuff from the old cap was still in the radiator.
anywho i replaced the radiator and problem solved
CXtypeR
Jan 26, 2007 08:10 PM
IloveNewt
Jan 12, 2004 10:24 AM
ATS*Mark
Dec 20, 2003 09:37 PM
drdavidge
Dec 15, 2002 05:58 PM
intekragsr
Oct 28, 2002 05:25 PM
