Tranny/car Problem!
Old Jul 7, 2011 | 08:54 PM
honda_ek9's Avatar
Default Tranny/car Problem!
Just bought a 4dr ek and tranny is having some problems. Was wondering if you guys know what it is.
PROBLEMS
-While starting in first gear and going, the car shakes like its about to die. Car shakes like no other and my buddy says that my muffler was moving back and forth(just like how when slow or cars take off at the tracks and the muffler moves back and forth.
-First gear has a whining noise.
Could it be the tranny or could it be that the fluid is low?? Need help ASAP!!
Thanks
Old Jul 8, 2011 | 06:09 AM
EdGe(161)'s Avatar
Default Re: Tranny/car Problem!
Thanks
I FEEL YOUR PAIN! i'm going through the EXACT same sh*t right now bud , ps the tranny flush DID NOT help i just did it to prolong the life of the synchro's (try a little lucas stop slip good on mt's as well).... anyway del sol is shaking and jump upon low rpm accel... also whines like a race car with straight cut gears...car accels terribly SLOW etc.... its pretty bad i think i need a new tranny AND a clutch/pressure plate
Old Jul 8, 2011 | 06:14 AM
virgineg6's Avatar
Check all your motor mounts
Old Jul 8, 2011 | 10:34 AM
EdGe(161)'s Avatar
i have brand new innovative racing mounts on all 3 primary mounts and i still utilize the front passenger side tourque mount as a sort of "insurance" .....anyway just for ***** n' giggles i checked them ....they are solid...... and as i said i have the EXACT same issues as OP
note.... take a look around on honda tech ALOT of tranny issues going on nowadays...i think its primarily due to the fact that we're all nearing two decades worth of service on these transmissions ( or at least i am) being powered by EG chasis motors and transmissions. Another thing to consider is with the relative abundance of used honda transmissions most people opt to swap them out rather than pursue a costly QUALITY rebuild...the sad truth behind that is, in most cases you're really just swapping in someone else's headache and neglect.. my tranny has about 220k on it and though i maintained the fluid well i think its just about had it ...after all with the way i drive i sure as hell didnt expect it to last forever
Old Jul 8, 2011 | 10:46 AM
fleabag's Avatar
Does starting off in 2nd gear change anything? My guess is you have an engine problem more than you have a transmission problem.
Old Jul 9, 2011 | 03:52 AM
EdGe(161)'s Avatar
second will only increase the jerking motion (haha jerking motion) but yeah its when i accel at low rpms that it feels like the car is struggling and the clutch is slipping/engaging..... at driving speed everything is perfectly fine .... the last time i had the tranny out there was a ton of play at the input shaft
Old Jul 9, 2011 | 09:13 PM
honda_ek9's Avatar
Edge- Yeah seems like we both are going throw the same issue. sucks. hahaa. But yea second gears still jerks. Tried it last time i drove the damn car. I wonder if changing out the tranny will make a difference?
Old Jul 10, 2011 | 03:59 AM
EdGe(161)'s Avatar
thats what im planning on doin' man ...but probably wont get to it for another two weeks .... if u beat me to it let me know your results.... i think im going to run a new clutch/pressure plate while im at it too.... either way gotta fix it lol looks like i cant drive a stick worth a *hit when im leaving stop lights lol
Old Jul 10, 2011 | 05:43 AM
HondaCivicSE's Avatar
worn bearing in your transmission, i had the same problem.
Old Jul 10, 2011 | 07:33 AM
fleabag's Avatar
I'd be great if OP would heed this advice instead of doing the lazy and waste of time option of just buying another used transmission which will fail in the exact same way.
Old Jul 10, 2011 | 08:02 AM
Former User's Avatar
Sounds like a worn clutch problem to me.
Old Jul 10, 2011 | 08:13 AM
sobapan's Avatar
I wonder if i have the same problem as you guys...
Mine shakes real bad if you try to ease off slow and go from a stop, but if i give it a lot of gas, like 3k rpm or more when i let go...it doesn't shake one bit. And if i switch to 2nd while it's still shaking..yeah it will keep shaking. It's a real nuisance.
Old Jul 10, 2011 | 09:53 AM
honda_ek9's Avatar
Yea will def let you if i do it before you. But i think you might beat me to it first. haha. still got some bills i have to worry bout first. But if you end up getting it done first you shuld let me know. haha.but yea stopping at a red light n going make me look like i dnt know how to drive stick. lol pretty embarrassing. people behind me looking at n seeing my car/exhaust jerking back and forth. hahaha!!!
Old Jul 10, 2011 | 09:55 AM
honda_ek9's Avatar
Sounds like your in the same shoes as us bro. haha. When i drive it i have to rev real high n ride the damn clutch just so it wnt shake. sometimes it'll shake alittle bit so i slowly ease on the clutch n gas it more. its bad so tats why i stop driving tat car.
Old Jul 11, 2011 | 07:20 AM
honda_ek9's Avatar
TTT
Old Jul 11, 2011 | 07:25 AM
kaiba's Avatar
Clutch and input shaft bearing.
Old Jul 11, 2011 | 08:17 AM
hyperblu's Avatar
Most likely clutch... Very common problem at my dealership...
Old Jul 13, 2011 | 12:09 AM
honda_ek9's Avatar
so i shuld just change the clutch? or just i do that n get a new trans??
Old Jul 13, 2011 | 02:48 AM
CivicBlacksheep's Avatar
10 Year Member
+1 for clutch
Old Jul 13, 2011 | 07:53 AM
hyperblu's Avatar
Not very common to have manual transmissions to slip without the synchros going first... You would be grinding and losing gears before your tranny is toast... My old clutch was making the car shutter at take off because the friction plate was so worn and it was only getting a solid bite half the time...
Old Jul 13, 2011 | 04:52 PM
honda_ek9's Avatar
im assuming its the clutch then? if i have to replace both clutch flywheel n trans then i mine as well do a ls swap.
Old Jul 13, 2011 | 06:48 PM
hyperblu's Avatar
Nobody said anything about replacing a flywheel and trans?
Old Jul 14, 2011 | 12:13 AM
honda_ek9's Avatar
yea but it seems like it could be coming from the trans. but i wouldnt know. still trying to figure it out. hopefully soon.
Old Jul 14, 2011 | 01:42 PM
honda_ek9's Avatar
TTT
Old Jul 14, 2011 | 07:46 PM
sobapan's Avatar
hey even though i thought it was the tranny at first too, well now i think it's the clutch. i burned the clutch recently by starting from a stop in 3rd gear. after that, my car didn't shake at all for the next few days. the shake came back but yeah, i have an ebay clutch so its no wonder it wasn't good from the start...
88 EF Hatch
Transmission & Drivetrain
Jul 24, 2009 08:27 PM
924doorEG
May 28, 2007 07:38 PM
turbod16y7vtec
Oct 29, 2004 09:03 PM
RTW DC2R
Feb 9, 2004 09:51 AM
