idling issues
Old Jul 7, 2011 | 03:04 PM
sullins's Avatar
Default idling issues
I have a 95 interga gsr and its idling really ruff. it fluxuates between 1,000 and 2500 rpms at idle. there is no check engine light and if its a vacum leak its sneaky. has anyone else had this problem or no how to go about fixing it any help would be awesome.
Old Jul 7, 2011 | 03:30 PM
imbest123's Avatar
Default Re: idling issues
first steps to fix a fluctuating idle are cleaning the fast idle thermo valve and idle air control valve.
Old Jul 7, 2011 | 04:45 PM
sullins's Avatar
is that the valve on the bottom of the throttle body
Old Jul 7, 2011 | 05:11 PM
koss1229's Avatar
Did this happen out of nowhere and all of a sudden or have you done some work lately?
Clean that FITV on the bottom of the throttle body and the IACV.
There are plenty of write-ups all over the place.
Reply back when done, let us know what happened.
Old Jul 7, 2011 | 06:02 PM
sullins's Avatar
i have swaped the iacv and i just tryed cleaning the fitv but im not sure i got it well enough couldnt get the coolant inlet off but as it stands still fluxuates
Old Jul 7, 2011 | 07:38 PM
LivinLoud94's Avatar
it could be vac leak make sure you torque the throttle body bolts to spec i think its like 20ft lbs and check for a cracked brake booster hose
Old Jul 8, 2011 | 04:37 PM
Kyogie12's Avatar
Make sure TB is clean, bolted. Check for Vac leaks. I come from DSMs and that's usually the problem and the easiest fix.
Old Jul 9, 2011 | 12:42 PM
sullins's Avatar
its definately not he FITV i took it to a local machine shop and sand blasted and cleaned everything still idles rough
Old Jul 11, 2011 | 03:36 PM
sullins's Avatar
Thanks for all your help guys it ended up being the adjustment on the tps.
edmfactory
Jan 13, 2014 06:54 PM
dth0ng69
Mar 17, 2009 08:31 PM
slo_ej8
May 21, 2008 08:44 PM
jdm_racer831
Dec 22, 2007 08:03 AM
caLiH22A
Aug 24, 2004 08:05 PM
