need help! oil spitting out of exhaust
so here's the deal i have a small exhaust leak inbetween my turbo hot mani side and the down pipe cause its missing two bolts and this morning it started smoking i pop the hood and theres oil all over my dp, block, and rad support. i have no idea how this is happening but i checked the oil and it was really low so i put a quart in and it stopped smoking after it warmed up and stopped spitting oil.. not sure whats wrong please help!!
yuppie the turbo(bone) song
the down pipes connected to the turbo, the turbos connected to the manifold, the manifold connected to the motor
yes please pic with the down pipe off
first bugs bunny/road runner movie, then bone song. makes me feel like a kid again
okay so i took my charge piping off and there was tons of oil which means i have blowby. my question is now what size oil restrictor do i need for a garret 60trim t3/t4 turbo? or do i need one at all?
oops sorry i guess its journal bearing so no need for a restrictor buttt what size oil line should i use? im not sure on the size i already have
A 0.065" restrictor usually works, however a leaking turbo will usually need a rebuild. Just like poping a headgasket requires a new HG installed first...
Try the restritor and see if it clears up. Its not like poping a headgasket. From what i'm starting to understand those ring seals are not actually there to stop oil leaking. There there to stop Air and exhaust gas getting into the CHRA.
i read on Garrett's actual website that a restrictor is not needed when running a journal bearing turbo because it reguires more oil. yes i know the seals went bad on my old turbo that one is gone. i just need to know the size oil line to run.
