Power window issue
Old Jul 6, 2011 | 05:28 AM
stoney0264's Avatar
Default Power window issue
I have been having problems with the power window on the passengers side in my 99 accord 2 door. To begin with, the window regulator and motor had to be replaced. I got that complete and the window worked fine for a couple of times when I was trying it out. Got the door put back together and tried it again and it worked. I went to the drivers side and tried the switch from there and it would not work. Went back to the passengers side and now it no longer works. I checked the fuse, and it is fine. Any ideas?
Old Jul 6, 2011 | 02:52 PM
75aces's Avatar
Default Re: Power window issue
It Could be your switch. Go to your local junkyard and see if you could get the wire or the connector. This will allow you to test the motor independent of the switch. You can test with battery.
kwae
Sep 29, 2017 10:32 AM
einzelherz
Dec 16, 2011 02:58 PM
speedfreak44
Aug 25, 2010 01:33 PM
Regal
Feb 27, 2009 06:39 AM
Ej1_coupe
May 29, 2006 06:39 PM
