HELP! installing oil pressure gauge on b18b! HURRY!
Old Oct 1, 2002 | 08:52 PM
pr0jektdc2's Avatar
Default HELP! installing oil pressure gauge on b18b! HURRY!
ARGHH i finally bought all of my crap to install this darn gauge..so as of now i have a brass T fitting 1/8 all hooked up to the gauge and just waiting to be put into the block! BUT wait! i cant get the damn sensor thing off the back of the block next to the oil filter! am i supposed to pull or twist it off...it seems like a rubber grommet cuz thats all i can feel..i dont feel a nut [dont even think about it im serious!] or anything and ive already tried yankin at it but nada! TIA!!!!!
Old Oct 1, 2002 | 09:14 PM
94tegAddict's Avatar
Default Re: HELP! installing oil pressure gauge on b18b! HURRY! (pr0jektdc2)
damn.. that thing will be soooo hard to pull out with bare hands or minimum tools...... just take it to the mechanic.. make sure they drain the oil first..
[Modified by 94tegAddict, 6:15 AM 10/2/2002]
Old Oct 1, 2002 | 09:42 PM
KLN's Avatar
KLN
Default Re: HELP! installing oil pressure gauge on b18b! HURRY! (94tegAddict)
you have to pull off the black rubber sensor thingy first...that is just the wires that read your stock oil pressure sensor
then once that is off, you need a really big deep socket to take out that oil sensor, i don't think you'll be able to do it by hand....
Old Oct 1, 2002 | 09:53 PM
kingrobby's Avatar
This is for an ELECTRICAL OIL PRESSURE GAUGE. I just put a oil pressure gauge on my 94 LS and it wasnt that big of a pain. Jack up the car and get underneath (JACK STANDS!!!!!!!) Find the oil pressure senser by the oil filter and pull the rubber grommet loose from the nut, then you can pull the electrical connector off. Its kind of a pain i had to use a screwdriver to pry it off. Then get a big socket (i think i used a 7\8 or 15\16th DEEP SOCKET) and a ratchet to unscrew it. There isn't a lot of room but it came out pretty easy. Then coat the threads of the 1\8th inch tee with some liquid teflon and screw it into the block, same thing with the elctrical sender and then the stock sensor. and then it should be done except for the wiring. Hope this helped.
Old Oct 2, 2002 | 06:27 AM
Project X's Avatar
http://www.theoldone.com/articles/oilpressure/
Old Oct 2, 2002 | 06:36 AM
TurbothisLS's Avatar
Default Re: HELP! installing oil pressure gauge on b18b! HURRY! (Project X)
yeah, take the rubber grommet and slide it off the nut.
it's like a 23 mm socket or something like that...maybe 22mm
it helps to pull your oil filter off to give some more room.
just top off the oil after you're done...
Old Oct 2, 2002 | 08:39 AM
arw321's Avatar
Default Re: HELP! installing oil pressure gauge on b18b! HURRY! (TurbothisLS)
FOLLOW ENDYN'S INSTRUCTIONS.
Use steel braided hose to relieve the stress that the sending unit(s) will be putting on your block.
If you don't, the fittings will crack (or worse) and you will be leaking oil.
This happened to me, so I re-did it the right way.
HTH.
Adam
OGMatt
Aug 15, 2011 01:11 PM
cjmitthun
75
Nov 21, 2006 08:35 PM
ttaplin
Oct 6, 2005 03:36 PM
jisecup
Nov 19, 2003 10:00 PM
