D15B7 Turbo Line Vacumm Question
Old Jul 5, 2011 | 04:26 PM
streethondar's Avatar
Default D15B7 Turbo Line Vacumm Question
Where on the Intake Manifold do i get the air for the BOV and Wastegate? I have a air port on my turbo it's self but i will be using that for my boost gauge.
Old Jul 5, 2011 | 04:29 PM
Gunmetal_B20_Hatch's Avatar
Default Re: D15B7 Turbo Line Vacumm Question
WG boost reference goes to the compressor housing on the turbo.
BOV & gauge should go to the intake mani... doesnt really matter where.
Old Jul 5, 2011 | 04:31 PM
So the one of the ports on the back with a t-fitting for the bov and gauge will be fine?
Old Jul 5, 2011 | 04:49 PM
So the one orf the ports on the back with a t-fitting for the bov and gauge will be fine?
yessir
Old Jul 5, 2011 | 06:49 PM
yessir
Where would i route the boost controller coming form the top of the wastegate?
Old Jul 5, 2011 | 07:49 PM
Old Jul 12, 2011 | 11:20 AM
I bought one of these manual boost control and a diagram would be of much help on how to hook this thing up. It has a boost control and a check valve with arrows on them the arrows need to point towards the wastegate... so i have a 2 vac ports on the controller and 3 vac ports on the check valve (2 through and 1 on top) the pic is what i have.
Old Jul 12, 2011 | 11:36 AM
maxwellmercer's Avatar
Tee into the fpr line for the wastegate, and the bov should have its own port off the manifold. Like the cruise control nipple persay.
Old Jul 12, 2011 | 11:56 AM
dpetro1's Avatar
wastegate does not need and should not get vaccuum. he should use the compressor housing for the wg boost reference.
no offense but if you didn't buy that ebay crap you probably would have gotten a product with instructions from a copmpany with a website and telephone # you could use for tech support.
but since yours is just a knock-off of another company i've seen, ill assume you can follow their instructions http://www.turbosmartonline.com/inde...ownload&id=200
Old Jul 12, 2011 | 12:28 PM
[QUOTE=dpetro1;45629308]
Tee into the fpr line for the wastegate[\QUOTE]
Thanks! i have it correctly installed. I have 2 ports on my wastegate and it said to use the top port on the wastegate for the boost controller. But that install there said i can run it into the side port and just still vent the top port. But i will leave it like it is for now and it should work.
Old Jul 12, 2011 | 12:36 PM
kyden's Avatar
top port is not used for a manual boost controller.
Old Jul 12, 2011 | 12:56 PM
whats it used for then?
Old Jul 12, 2011 | 01:08 PM
Ok, finally i think i figured this out.
1.) Put the check valve in between the vac hose coming form the trubo hosing to the side wategate port.
2.) ran vac hose form top of check valve to the bottom port on the boost controller.
3.) ran a vac hose form the top port of the boost controller to the top port on the wastegate.
I think this is how it should be setup.
Old Jul 12, 2011 | 04:09 PM
wrong
Old Jul 12, 2011 | 05:33 PM
wrong
then whats the correct steps?
Old Jul 13, 2011 | 07:56 AM
dpetro1's Avatar
whats wrong with the instructions i posted?
Old Jul 13, 2011 | 07:59 AM
dpetro1's Avatar
i was under the same impression...
Old Jul 13, 2011 | 11:09 AM
So the top port on the booster controller and waste gate should just vent into the air?
Old Jul 13, 2011 | 11:36 AM
EsotericImage's Avatar
Retired Moderator
Just throw the boost controller away and use the WG to control your boost.
I can see this being a disaster already
91lsteg
Nov 21, 2009 10:41 AM
krysted9354
May 10, 2009 11:13 AM
esedulerp5tenin
May 21, 2007 02:56 PM
jdm-ray
May 15, 2005 09:37 PM
_Endless_
Nov 18, 2003 10:32 PM
