gauge not reading boost VID!!!
Old May 20, 2007 | 09:03 PM
esedulerp5tenin's Avatar
Default gauge not reading boost VID!!!
i installed my boost gauge before the turbo, and it read vaccuum perfectly.
when i finished the turbo install, i Tee'd my hks ssqv off the same hose, and now it doesn't move at all. it just stays still the entire time, around 1 pound.
t3/t4 57 trim
tial 38mm
hks ssqv
oh yea, i'm still on the phearable basemap, if that matters.
and this is just a walkaround of my car, nothin too fancy
Old May 20, 2007 | 10:14 PM
HiProfile's Avatar
Default Re: gauge not reading boost VID!!! (esedulerp5tenin)
I guess I'd ask where the other side of the bov line goes. Its possible you have a boost leak (not uncommon), but if it never sees vacuum ever, that means the other end isn't connected to the intake manifold. The gauge should be connected somewhere after the TB, I always recommend a dist. mani that's tee'd off the brake booster line.
Old May 21, 2007 | 07:26 AM
Default Re: gauge not reading boost VID!!! (HiProfile)
oh yea, forgot that. the gauge and BOV are going to the IM
Old May 21, 2007 | 02:24 PM
as gay as this sounds.... i unhooked the hose and blew into it as hard as i could, but the needle didn't move
this should normally be enough pressure, right?
is the gauge shot?
Old May 21, 2007 | 02:56 PM
GuNnErGoD's Avatar
Try getting a vacuum manifold. It will allow you to better diagnose the problem and cleanup your engine bay in the process.
91lsteg
Nov 21, 2009 10:41 AM
hondamonkey
Aug 6, 2007 07:02 PM
FragSyndrome
May 29, 2004 05:10 AM
mattcalica
Jan 13, 2004 10:13 AM
luderone
May 22, 2003 04:52 PM
