Bad gas can cause high afr's
Old Jul 5, 2011 | 08:41 AM
carlos8's Avatar
Default Bad gas can cause high afr's
hi, i fill half tank with 93 on my civic ls/vtec turbo, few minutes later when i
stop the afr's goes to 16-17 when normal is 13.7 to 14 ,this can be a bad
fuel. I check for vacuum and exhaust leaks all looks fine. AEM wide band.
thanks
Old Jul 5, 2011 | 09:41 AM
apexi_rsx's Avatar
Default Re: Bad gas can cause high afr's
good possibility u got a bad batch of gas. maybe a good idea to run some octane booster even though they don't raise octane much. its best u stay out of boost until u get rid of the gas. sometimes u need to recalibrate the wideband and try that and see if it changes.
Old Jul 5, 2011 | 10:01 AM
carlos8's Avatar
Thanks, you know how to recalibrate the AEM wideband.
Old Jul 5, 2011 | 10:48 AM
owneyboy's Avatar
i believe the aem's CANT be re-calibrate-able.. widebands as well as any other o2 sensors go bad. but if thats the case and your wideband is bad than it pretty much went from a pos to junk
Old Jul 5, 2011 | 11:14 AM
carlos8's Avatar
yes i'm reading the instructions and no mention nothing about recalibranion
oh_dam
May 12, 2010 08:49 AM
91_HB
Mar 22, 2005 03:24 PM
E Swift
Dec 20, 2003 04:37 PM
FourthGenHatch
Feb 25, 2003 07:40 PM
DIRep972
Oct 11, 2001 05:02 AM
