bad gas mileage?
Old May 10, 2010 | 10:40 PM
oh_dam's Avatar
Default bad gas mileage?
i notice most you turbo guys are getting pretty good gas mileage, i can only get a about 240 a full tank cruising the whole tank i notice some of you turbo guys get better gas mileage than when ya were all motor, i dont see why im getting bad on a stock turbo ls
Old May 11, 2010 | 07:27 AM
keving85's Avatar
Default Re: bad gas mileage?
All in how good your tuner is man
what afr's are you showing while cruising. I see around 14.4-15.1
Old May 11, 2010 | 09:33 AM
moserd1's Avatar
you may have the wrong tune. If your running rich then you could be wasting a lot of gas.
Old May 11, 2010 | 05:17 PM
Turbo-LS's Avatar
Its all in the tune. I get about 32mpg driving normal and about 25mpg boosting a good amount in a stroked gsr about 400whp
Old May 11, 2010 | 07:02 PM
Honda Bull's Avatar
Yep. Definitely in the tune and how much you use that right foot. I'm 30-32 mpg with regular country road and town driving. 40-45 mpg highway. GSR trans, Precision 880cc's, 1.8L, GSR cams, 92-93 octane, 2350 lbs, tuned by John Kerr of J-K-Tuning / Innovative Motorworks.
Via NepTune's wideband targeting, car cruises around at 13.8 - 14.8 AFR. Idles anywhere from 12.0 - 15.5 depending on engine temp. Sometimes it'll spike out to the 16:1 at idle randomly. Basically, make sure you aren't cruising in the 11 or 12s. :p
Old May 11, 2010 | 09:51 PM
oh_dam's Avatar
thanks for all the great info, but this is weird i get good gas mileage city wise only but on highway its like the worst of worst ever and thats just cruising 60
Old May 12, 2010 | 08:49 AM
HiProfile's Avatar
Sounds to me your tuner tuned boost and moderate load (low vacuum, light accerlaration), but not the cruising/med load cells. Some people will be lazy and not tune partial throttle all that well. Combine that with disabling your oxygen sensor, and you're at the mercy of a potentially bad tune.
maintain
May 20, 2008 08:51 PM
westbdbe21
Honda Civic (2006 - 2015)
May 25, 2007 06:49 AM
corey's96GSR
Jun 6, 2004 09:06 AM
Muckman
Oct 30, 2001 09:12 AM
