help!! misfire at full throttle!
Old Jul 3, 2011 | 10:23 PM
silly singlecam's Avatar
Icon3 help!! misfire at full throttle!
hi guys im new to HT. i already know most people nag and nag "hey noob theres a search button". i searched and cant find a topic to my specific problem. i have a 95 ex coupe with a jdm d15b block and a z6 head. the problem started when i spun a rod in my z6 block. a friend of mine helped me swap the block with the d15b i bought for cheap and when we got it back together it would start cutting out and sputtering once it hit 3k at anything more then half throttle. we are stummped as to what it is.
Map, tps, dizzy, injectors, ecu, vtec solenoid, and FPR have been swapped with ones from a fully running car. the fuel filter and air filter are new, new plugs and wires, its in perfect time (even had double checked at a shop). im just starting to run out of ideas. any help would be appriciated. i cant take only being able to rev out at half throttle!
Old Jul 3, 2011 | 10:30 PM
teggi's Avatar
Default Re: help!! misfire at full throttle!
Have you checked cap and rotor?
Old Jul 3, 2011 | 10:35 PM
the whole distributor was swapped out with one from a friends car. that was the first thing i checked
Old Jul 4, 2011 | 06:01 AM
HAMOTORSPORTS's Avatar
you probably have the map and tps plugs flip-flopped..
Old Jul 4, 2011 | 07:56 AM
Former User's Avatar
Cylinder compressions?
Old Jul 4, 2011 | 01:36 PM
Map an tps are not flipped. Already checked that. And I personally didn't check the compression but the shop I took it to that double checked the timing also checked the tps and vacuum lines
Old Jul 4, 2011 | 08:06 PM
he checked the compression on all cyliders and said that it was ok. hes looked over a couple things and connot see what wrong either
Old Jul 6, 2011 | 01:58 PM
anybody ideas would b great. the only thing that i havent changed was the fuel pump. it has a walbro 255 in it so maybe its just giving the car too much fuel or something. im not sure but damn near every sensor has been swapped
Old Sep 11, 2011 | 08:36 AM
update* i recently pinched the fuel line going from the fuel filter to the rail and it started revving to 4.5k now so it has to be fuel related. i swapped in a stack fuel pump and ditched to walbro 255 but that changed nothing. im thinking about getting a wideband and seeing what my afr
fyjimo_jr
Feb 4, 2015 10:33 AM
19_hatch_93
Jan 11, 2009 08:24 PM
tacorunner87
14
Jan 3, 2009 09:05 PM
enduronut
May 31, 2008 10:25 AM
IMPORTMyth01
12
Nov 27, 2006 05:44 AM
