Just converted PW/PL/PM... Issues
I just did the power window/locks/mirrors yesterday (I had all the necessary parts for it to be a plug and play, even checked the harness # to see if it was the same year 96-98). Well my passenger side everything works well, but the driver side I had issues with the power window not going up and the power mirror's function for Driverside (left & right) locks/unlocks the doors. The master switch for the power window/locks/mirrors works well on the passenger side. The driverside only the power locks work, the power mirrors (work only up and down) and power windows (nothing functional). Thanks in advance.
did you hook up all the ground's on the floor harness ? check the harness where it goes into the plug for the drivers door the harness mine had like 15 broken wire's they flex there everytime you open the door
Check your g.d. wiring ... if you hooked it up properly, then it would work! It's plug and play, after all. If there's a bad ground then a lot of weird isht can happen ... that's where I'd start.
How many grounds are there in the floor harness? I remember being just only one, which was by the foot rest.. Just a note I did hook up the rear wipers and the washer and they do work. I'll look at wires on the driver side door and check for more grounds that I didn't see. I just put direct power to the regulator yesterday and no function.. Also what are the chances for the brain to be dead on one side??
Cuong-nutz
77
Mar 24, 2013 08:47 AM
Slammed_am
Sep 15, 2011 04:31 PM
170whp-B16a
Northeast (Sales)
May 30, 2010 09:12 PM
mrxwickedx626
Aug 10, 2005 06:38 PM
accord, allintextpowered, civic, driverside, honda, left, mirrow, pl, pm, power, pw, vbulletinpw, window, wiring, works
