which ecu should i use
Old Jun 27, 2011 | 03:16 PM
catchdz's Avatar
Post which ecu should i use
is it better to run a stock p5p or a p5m for a h23a swap, or is there another stock ecu that i should use want to buy the motor and ecu at one time so i need help asap. TIA
Old Jun 28, 2011 | 03:48 AM
mherkamp's Avatar
Default Re: which ecu should i use
I guess we could use a little more info, like what car is this going in, what did the engine come out of, OBD1 or 2 for each? Also, what wiring harness are you using? Maybe some of that info can get us going toward a solution.
GL
Mike
Old Jun 28, 2011 | 07:25 AM
pentaq's Avatar
p5m or p5p will do fine
Old Jun 28, 2011 | 08:11 AM
THC07's Avatar
your not gonna get either to work unless you pay to get the immo removed from the ecu, contact katman for that. but then again, need more info, what car? year? you may be able to re-flash the key-ring but i dunno what car you have.
otherwise you should use a obd1 ecu. a chipped ecu with a h23 vtec tune.
I have a few chipped ecus and i drive an h23vtec. lmk if i can sell you an ecu with a street tuned h23v basemap.
Old Jun 28, 2011 | 03:03 PM
catchdz's Avatar
oops my bad i have a 96 obd2 prelude si 2.3 non-tec im going to replace my motor with a 2000 jdm h23a vtec obd2 i have access to both engine harnesses, ne thing else u need???
as for what u said THC07 the jdm p5m doesnt have a immo its what i figured the be next best option other than a p5p
Old Jun 29, 2011 | 06:04 PM
THC07's Avatar
interesting... i did not know this.
any interest in just running obd1? or how about the obd2 p13 ecu. are you wanting to keep IAB funtion?
Old Jun 30, 2011 | 03:59 AM
catchdz's Avatar
I want to keep it obd2 can't find a p13 ecu as far as IAB not sure what thaT is . U wanna shed some light on that for me?
Old Jun 30, 2011 | 08:41 AM
typemismatch's Avatar
Honda owns me
Intake air bypass valves in the intake manifold. They open at higher RPMs to let more air into the motor.
I gutted mine, they're just flappers screwed to a rail that turns to open them.
Old Jun 30, 2011 | 11:37 AM
THC07's Avatar
lol they are more than just flappers, IABs are a Awesome design. and work great.
using them or not all depends on how you build your motor.
obd2 p13's are hard to find, i have two of them. when i see one for a good price i buy it lol. i have seen people selling them for as much as 300$, crazy rare! along with the Type S intake manifolds.
Old Jun 30, 2011 | 12:41 PM
catchdz's Avatar
What =\, I just wanted to know if I get a complete (2000) h23a with everything on it can I put it in my 96 obd2 that's what I now know to be prewired for vtec, and will it run good I don't wanna go over borad and upgrade the **** outta it I just want to get a good motor that runs,
Old Jun 30, 2011 | 12:45 PM
mherkamp's Avatar
Dude, obd1 conversion ftw. Use the tools available (Neptune, eCtune, Hondata, Crome) and tune it right. Wide band and go! Its such a freeing feeling to be able to control how your car runs with your own laptop.
Old Jun 30, 2011 | 12:55 PM
catchdz's Avatar
Kamp I hear what ur saying but I'm not set up for that **** I'm an alignment specialist I'm not to keen on motor and ecu but I blew my h23a1 and i wanted to get a little upgrade for my money and figured if I dropped the H23a in my **** not only would my car run id get myself a little upgrade in the process?
Old Jul 2, 2011 | 03:11 PM
slomofo's Avatar
GDD Member
Use the ECU that comes with the engine and get this jumper harness to plug into your car:
http://www.rywire.com/catalog/obd2a-...b2491271d3c3d9
The JDM ECU doesn't have immobilizer so it should work, but if your state does OBDII Emissions testing then you'll have a problem because JDM ECUs don't send a power signal to the USDM 16-pin DLC connector nor do they have readiness monitors so you'll probably have to use your stock ECU to pass emissions, but outside of emissions you'll be good.
Edit: You're still going to have to wire up VTEC, knock sensor, IAB, and possibly rewire EGR but this option may prove more convenient than tracking down an OBD2 P13.
Old Jul 9, 2011 | 06:54 PM
catchdz's Avatar
Thank you slomofo that's what I was hoping to hear and no I don't have to worry about any emissions or ne thing like that. Should I use the wire harness from the original h23a1 or the one that comes with the H23a ??
Old Jul 16, 2011 | 05:59 PM
catchdz's Avatar
ok so i have swaped the motor bracket, p/s bracket (with some mods), swaped over the distributor and plug in the wire harness over from my h23a1, my problem is that on the h23a intake manifold i have to plugs one in the back and one in the front that my old h23a1 didnt have what are they and what do i have to do to get them hooked here r some pics of the two plugs
Old Jul 16, 2011 | 06:14 PM
catchdz's Avatar
the back one wont upload sry this is the only on i have.
Zac W.
Aug 2, 2011 06:31 PM
dwarfsinhondas
Engine Management and Tuning
Apr 7, 2008 11:47 PM
kanSiR
Nov 8, 2007 08:02 AM
eater_eg6
Dec 12, 2005 12:54 AM
4drb18ek
Mar 1, 2003 07:42 AM
