96 si non vtec prewired for vtec?
Old Jun 27, 2011 | 11:14 AM
catchdz's Avatar
Post 96 si non vtec prewired for vtec?
wats good people i just wanted to know if my 96 si 2.3 non vtec was prewired for vtec or not? how do u know? where r the cables? Does that mean i can put ne motor in my car and vtec will automatically work(with the right ecu)? ne thing helps TIA
Old Jun 27, 2011 | 11:42 AM
95SE's Avatar
Default Re: 96 si non vtec prewired for vtec?
misinformation deleted by me
Old Jun 27, 2011 | 12:23 PM
catchdz's Avatar
was thinking bout putting a h23a in my car but as i read up on it some people say yes it works some say no that u have to change out the entire wire harness from head light to the tail lights if it does work what ecu should i get i have a 5 spd
Old Jun 27, 2011 | 12:40 PM
95SE's Avatar
dude you are lazy google this chit
Old Jun 27, 2011 | 12:51 PM
catchdz's Avatar
im not lazy im just not finding the answer so i figured id ask u guys
Old Jun 27, 2011 | 05:40 PM
minilogoguy18's Avatar
95SE is wrong, that blue wire is for a tachometer that can be plugged up to help with things like idle adjustment. The only wire you have if any is the one for the VTEC solenoid which is a green/yellow single wire plug that is near your pass shock tower and will be plugged into a dummy plug. The other one you need you'll have to add but ONLY to the engine harness, the main harness leading to the ECU will already have it. The big plug on your engine harness will have a blank spot, this pic shows it, the plug next to the ABS.
http://img844.imageshack.us/img844/4800/1003101122.jpg
This shows where to find the grn/yel wire for the solenoid...
http://img706.imageshack.us/img706/935/1003101121.jpg
Helps if your motor comes with a harness, I just took the plug for the oil pressure switch from it, 2 wires, black is just grounded to whatever.
http://img225.imageshack.us/img225/3...itchwiring.png
Old Jun 28, 2011 | 02:50 PM
catchdz's Avatar
ok so what r u saying is, i have to take the plug ur pointing at, plug it into the vtec solenoid, then add the wire into the missing slot on the plug next to the ABS, and run it to the oil pressure switch? thats located right next to where i plug the first plug in???
Old Jun 28, 2011 | 04:47 PM
Yes, on the spool valve body the solenoid will be on the top, easy to figure out since both plugs are different, just ground the black wire for the oil pressure switch wherever.
Old Jun 28, 2011 | 05:19 PM
catchdz's Avatar
should i use the stock engine harness or the one that comes with the h23a?
Old Jun 28, 2011 | 06:57 PM
95SE's Avatar
Are you going to H22a or H23a because your last post says H23a (the blue top beast). If so there is more to do, such as but not limited too h22 injectors, h22 intake manifold, usdm h22/h23a1 fuel rail.... more but nit an exprt on it, something with the dizzy too.
Old Jun 29, 2011 | 03:49 PM
catchdz's Avatar
im gunna do the blue top, cant i just do a whole swap using everything from the h23a and a ecu ?
Old Jun 29, 2011 | 04:21 PM
snobordboy's Avatar
Moderator
The swap from H23a1 to H22a or h23a is EXACTLY the same. The H23A will benefit more from a good tune though, in my opinion.
Old Jun 29, 2011 | 05:31 PM
catchdz's Avatar
tune the motor or tune the ecu?
Ryan Arnold
May 7, 2016 05:54 PM
allsho
Jun 14, 2007 12:06 PM
GreddyCivic7
Feb 10, 2007 03:35 PM
9deuce9rr
Jan 7, 2004 03:17 PM
hondaless
Sep 17, 2002 06:33 PM
