vtec wiring
vtec wiring
ok so i am goin to wire in my vtec on my d16y8.. the problem being is i don't have any of the clips.. there is a green plug... when removed there is oil behind it(this is the plug to the vtec selondoid.) i was wondering how i could wire that in.. i don't have a junkyard wiht the male plug that plugs into it. thanx alot
eric
ps.. this is also goin into a 1995 civic hatch..
eric
Re: vtec wiring (HondaPartsHero)
Unless your '95 is an Si or an EX, you're going to have to run the VTEC wire all the way to the ECU anyways (not really far, just a foot or so inside the firewall.
I don't understand your question fully. Is your concern regarding the OBDII > OBDI on the VTEC solenoid?
Re: vtec wiring (94si94cx)
ok sorry i will try to make it more clear.. on the vtec selanoid there is a black clip that has a wire running from the selonoid. i know how to wire that one in.. now just believe that is a green plug that is screwed into the block.. how do i wire that in.. my car is not an si or anything.. allt he plugh as is two prongs inside it.. and i don't know how to wire that in
i have gone to auto reckers and none have that male end for it.. so any way to possible run it to the ecu..
92EG8
11
11-17-2006 08:50 PM
ilovemyb16a
05-18-2006 12:58 PM
