GSR swap need help
Old Jun 25, 2011 | 04:37 PM
nrowttocs4484's Avatar
Default GSR swap need help
I have a GSR Obd 1 head w/itr cams and b18c block running a skunk2 intake manifold with a S80 transmission but my issue is the ECU. The car came with a p28-a02 ECU I know this can't be right and if I'm not mistaken this ECU is for an automatic. The car runs ok but feels like I'm towing another car and the car doesn't really come alive till 7000rpm. My question is can I change out with another p28 ECU that's is for a manual and this will fix my problem or can I get a Obd 1 ECU that is for a GSR and use it even if I'm not using then stock manifold that has the butterfly valve? The car is a 93 coupe and everything else us fine except how the car pulls and vtec does work
Old Jun 25, 2011 | 05:59 PM
ekb16's Avatar
Default Re: GSR swap need help
chip a p28 or get a p30 ecu
Old Jun 25, 2011 | 06:29 PM
postman's Avatar
i believe you should actually be using a p72. been a while since i did any ecu work so you migth want to wait and confirm that.
Old Jun 26, 2011 | 04:24 AM
eg6ajk's Avatar
P28-a02 is a manual version, but in a stock version it runs way too lean for the B18c1, and redline is too low. Stock P72 will work but VTEC change over is at 4400rpm it will cause some bogging. To resolve - either chip it, or purchase already chipped p28/p30/p72 ecu. Many options.
http://www.xenocron.com/chipping-kit...cus-p-277.html
Old Jun 26, 2011 | 12:56 PM
Where is a good place to have the ECU chipped and the car tuned that is close to Fayetteville, nc
Old Jun 27, 2011 | 07:58 AM
xenocron's Avatar
How far is that from Asheville? Call Joseph Davis @ Redline Motorsports if thats close to you...
Old Jul 3, 2011 | 06:46 PM
jwaym24's Avatar
I send all my ecu work to John @ j-k tuning in PA ship to him and for like 50-75 he will chip and base map your ecu. He is verrrry good look him up on google. DYNO tuning there is real reasonable too
DA STRIKER
Feb 4, 2011 03:49 PM
whiteteggy44
Jan 31, 2011 02:00 PM
honda_gsr_b18c
Feb 26, 2010 05:39 AM
nub_pwn
Oct 9, 2006 03:57 AM
hybridmoose
Apr 24, 2003 03:50 PM
