Transmission & Drivetrain Gearboxes, Differentials, Clutches
lost clutch pressure again
Old Jun 24, 2011 | 04:27 PM
shocker911's Avatar
Default lost clutch pressure again
so i have bled my clutch 2 times now both times i lost my pressure when i started the car. When i bleed it it holds pressure just fine no problems at all. I will start the car a few times and there will be no problems at all with it then i just started the car a min ago and all the pressure is lost in the system.
i looked for leaks at any joint possible nothing at all i have even run a clean cloth around the joints to see if i can find a leak. nothing at all.
does anybody have any ideas? i know im going to hear air in the system or didnt close the slave tight enough but it has been done correctly just like the haynes manual says.
scoker83
16
May 12, 2014 07:01 PM
Techy
Oct 9, 2008 11:08 AM
JDM_SOHC
36
May 21, 2007 03:50 PM
thehatchninja
10
Mar 25, 2004 02:03 PM
93preludes
Aug 14, 2003 05:56 AM
