View Poll Results: What Should i use?
Using a -3an feed no restrictor?
53.33%
Using a -4an feed no restrictor?
6.67%
Using a -3an Feed with .65" restrictor??
40.00%
Voters: 15. You may not vote on this poll
Need advice! Oil restrictor on my Precision Turbo SC44?? Use one or not?? PLZ HELP!
Old Jun 22, 2011 | 07:03 PM
xkrazyxjbrkerx75's Avatar
Icon3 Need advice! Oil restrictor on my Precision Turbo SC44?? Use one or not?? PLZ HELP!
I am turboing my car, i want to make 300-350 hp.
I have a ported oil pump. My motor is a d16z6, fully built.
Im using a Rebuilt Precision SC44 Journal Bearing
Compressor Cover T04E 3" Inlet
Exhaust Housing T3
A/R .63
Exhaust Trim 63
My question is, has anyone used this turbo?? I have been searching around on people using oil restrictors due to their seals blowing.
My questions are
Do i need a oil restrictor?
What size oil feed line should i go with?
What oil return line should i go with??
My research-
ANY ONES ANSWERS WILL BE HELPFUL!
Please reply or answer to the poll please!
Old Jun 22, 2011 | 07:32 PM
redflaredcrx90's Avatar
Default Re: Need advice! Oil restrictor on my Precision Turbo SC44?? Use one or not?? PLZ HEL
just call precision
Old Jun 22, 2011 | 07:37 PM
MR.johnson's Avatar
-3 no restrictor is fine. ball bearing is where a restrictor should be used.
call them, know what your min and max oil pressure is.
Old Jun 22, 2011 | 07:59 PM
TheShodan's Avatar
Moderator
at Cold start and WOT if known. Anything over 80psi of oil pressure at either of those points, use no smaller than a .060 restrictor on your -3AN line.
Unfortunately, you will get conflicting information from Precision directly, because they don't look at the engine application closely enough to have a general idea of what the oil pressure is at that 2 main points. What works for Mitsu, may not work for Honda, or Subaru which uses very high oil pressures..
Old Jun 23, 2011 | 11:46 AM
thanks guys for replying but the poll is tied!
Old Jun 23, 2011 | 11:49 AM
Tootsie7944's Avatar
-3 an feed with a .060 restrictor...just get the one from full-race.
Old Jun 23, 2011 | 11:52 AM
can u show me a link,
Old Jun 23, 2011 | 01:22 PM
racebum's Avatar
i'm curious about this too and will do whatever you tell me to on this one.
so on a b18c you're saying to use a -3 and a .060 restrictor or just a -3 or a -3 with a .060 or larger?
precision just says a -3 but i also wondered about this since a stock ITR for example has some pretty hardcore oil psi, especially when cold
Old Jun 23, 2011 | 01:36 PM
MR.johnson's Avatar
We have never had any problems with a non ball bearing with a -3.
Old Jun 23, 2011 | 02:24 PM
TheShodan's Avatar
Moderator
Guys, I can't reiterate this enough. PLEASE GO BY THE OIL PRESSURE OF THE TURBOCHARGER AND ENGINE ON AN INDIVIDUAL BASIS. THIS IS NOT A ONE SIZE FITS ALL SOLUTION. ;-). IF NOT SURE, TRY WITHOUT ONE FIRST, THEN USE ONE IF NEEDED. ;-)
RULE OF THUMB .... If oil pressure is over 75-80psi at cold start and WOT, use restrictor of .065 or .060 REGARDLESS OF FEEDLINE SIZE. IT JUST MEANS WHAT YOU HAVE MAKES TOO MUCH OIL PRESSURE
Old Jun 23, 2011 | 11:27 PM
racebum's Avatar
i'm going to respond to this just because i'm guessing other educated novice's such as myself are curious. if we run a journal bearing with a -3 on a motor like that b18c5 that does have greater than 80psi will any turbo damage take place? or does it just start smoking which is the que to get a .065 restrictor?
Old Jun 24, 2011 | 03:33 AM
Turbo-LS's Avatar
If its run for a short period of time and pushes oil past the oil rings and then you instal a restrictor then it should be fine, if its ran for a long time pushing oil then most likely will need new oil rings. the oil rings are only designed to handle a mximum pressre of 65psi and just about all hondas at cold start up and wot push 70+ psi oil pressure. I've been running a restrictor .065 on my garrett turbo for years, works like a charm
Old Jun 24, 2011 | 04:58 AM
Tjabo's Avatar
This man speaks the truth. I'm not personally aware of one person who Precision has ever told to run a restrictor on a JB turbo, and a lot of times they are needed (as TheShodan has explained in this thread). I think Precision is causing some of their own problems... It's very strange.
(Oh, and I'm not voting for the same reason TheShodan said -- don't know enough about how everything is going to work out with your setup. I think a little trial and error may be necessary)
velisma
Jul 20, 2010 01:18 PM
j0keefe21
Aug 1, 2009 11:15 AM
Chee_dog
Aug 30, 2007 11:10 AM
boostedSI90hatch
May 16, 2007 12:26 AM
B20-T
Feb 12, 2003 03:04 PM
