.4 kg/cm^2, 3700 rpm...
Old Oct 1, 2002 | 12:08 PM
dustin's Avatar
Default .4 kg/cm^2, 3700 rpm...
... 20 degrees ignition advance... That's what I am running on 91 octane.
How much timing are you running at this RPM and this boost level? The J&S is pulling 6 degrees for some reason.
AFR is 11:1.
Old Oct 1, 2002 | 12:26 PM
boostaholic's Avatar
Default Re: .4 kg/cm^2, 3700 rpm... (dustin)
I'll plug in the laptop on my way home from work and tell ya That is unless you know off hand the conversion factor from Kpa to Kpsi to kg/cm^2.
Old Oct 1, 2002 | 12:30 PM
dustin's Avatar
Default Re: .4 kg/cm^2, 3700 rpm... (boostaholic)
KPA is just a scale of 14.7 from 1 to 100... 100KPA is 0 vacuum. 200 KPA is 14.7 psi or whatever....
Old Oct 1, 2002 | 12:54 PM
EE_Chris's Avatar
Not answering the Q, but Online Conversions may help you out here and in the future.
Old Oct 1, 2002 | 01:00 PM
That's a little under 5psi boost. Odd that your J&S is pulling that much timing. At 4psi boost and 3700rpm i'm running 25 degrees timing advance. This is on an LS motor, stock compression, and 93 octane. A/F at 12.0.
Old Oct 1, 2002 | 01:04 PM
LEON's Avatar
not answering you question, but why are you running 11.1 A/F at that boost and rpm?
Old Oct 1, 2002 | 01:31 PM
dustin's Avatar
it's actually almost 6psi boost...
sensitivity on the J&S is at 10 o'clock.... (per Kabir's recommendation) and this is a stock 10:1 GSR.
Old Oct 1, 2002 | 02:01 PM
Doh! My brain is racked right now so you'll have to forgive my math skills at the moment. Trying to get this damn patent together is killing my brain cells one by one.
laziebun
Engine Management and Tuning
Jan 26, 2009 03:43 AM
93civciv
Dec 4, 2007 05:23 PM
pipes
Feb 20, 2004 09:19 AM
SJP0tato
Nov 6, 2003 11:19 PM
hybrid901
Sep 11, 2002 05:33 PM
