Newbie needs help.
I just picked up a 94 ls integra. The cel was so i jumped the wires to get the code/codes and i got
# 15 Ignition Output Signal
#41 Primary Oxygen Sensor Heater
I know replacing the o2 sensor will more then likely fix code 41. But my question is what do i need to do with code #15 to fix the problem.
Thanks for any help.
Disregard the above post. I went and rechecked the cel and it was code #14 IAC (EACV) – Idle Air Control Valve. ILL pull it off tomorrow and give it a good bath in carb cleaner.
hatchedzex
May 24, 2004 05:12 PM
