Code 41: questions
Code 41: questions
code 41: primary oxygen sensor-heater circut malfunciton........can this cause the car to shut-off and idle irracticly???
and will replacing the 02 sensor solve the problem?
Thanks, mark
Thanks, mark
Re: Code 41: questions (R-1303)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-1303 »</TD></TR><TR><TD CLASS="quote">code 41: primary oxygen sensor-heater circut malfunciton........can this cause the car to shut-off and idle irracticly???
Thanks, mark</TD></TR></TABLE>
quick answer NO
quick answer NO
I changed my O2 sensor whiched caused the code 41 because the connector/wires hit the bottom part of the header and melted. The wires were crossing and that caused my idle to act all jacked up. I could have just re-wired it, but I got a replacement O2 for free, so I just did that. My idle went fine after I replaced it. I was bugging me because a Code 41 will not erase (at least permantly) by resetting the ecu. So for my particular case, fixing that fixed my idle as well.
Re: Code 41: questions (Sasebonian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sasebonian »</TD></TR><TR><TD CLASS="quote"> I was bugging me because a Code 41 will not erase (at least permantly) by resetting the ecu. </TD></TR></TABLE>
Mine did, once I repinned the ECU.
punkracer
02-01-2009 06:57 PM
