anyone here got turbo n 2.25 inch piping?
Old Oct 1, 2002 | 09:16 AM
DC2_Integra's Avatar
Default anyone here got turbo n 2.25 inch piping?
how do u like it? cause i think 3 inch piping exhaust will be too loud for me. So much much power am i going to lose just cause i run a 2.25 piping instead of a 3inch?
Old Oct 1, 2002 | 11:29 AM
mos's Avatar
mos
Default Re: anyone here got turbo n 2.25 inch piping? (DC2_Integra)
This is what I'm going to do, and I'm wondering also. I figure it will clip off your high RPM power. That's fine with me though because I have a small turbo, and I'm looking for a fast spool up time and fat powerband for the street. I doubt I'll make over 200 crank horses though. What are your power goals?
Old Oct 1, 2002 | 11:35 AM
dbman96's Avatar
New User
Default Re: anyone here got turbo n 2.25 inch piping? (mos)
I'm running 2.25 on my turbo gsr and I don't mind it. Still pulls plenty hard and makes the noise level pretty reasonable. I'm also running no cat which probably helps a lot. I really would prefer to have 3" but I already had the 2.25" exhaust so I never bothered to replace it. I'll have dyno #s soon.
Old Oct 1, 2002 | 01:32 PM
my power goal is 280 whp
Old Oct 1, 2002 | 02:58 PM
98hx99b18c's Avatar
At 280whp I would suggest going to the 3in.
Old Oct 1, 2002 | 03:13 PM
93LSivic's Avatar
Default Re: anyone here got turbo n 2.25 inch piping? (98hx99b18c)
Ok check my sig. No dyno #'s as of yet, but prolly around 265 or so. Im also running a test pipe. Downpipe is 2.5 though. I like it, its pretty quiet (except when the wastegate opens ) I am going 3" when money allows----2.25 isnt gonna help me get to 400 hp which Im shooting for on pump gaz
k thanks
Old Oct 1, 2002 | 03:16 PM
integra-modder's Avatar
for 280, I think 2.25 is a bit too much... the smalled id go if I were you would be a 2.75, maaaaaaaybe a 2.5
Old Oct 9, 2002 | 05:01 PM
mos's Avatar
mos
Default Re: anyone here got turbo n 2.25 inch piping? (integra-modder)
So the concensus is that:
2 inch maxes out at about 200hp
2.25 maxes out at about 240ish
2.5 maxes out at about 300ish
3 maxes out at about 400ish
Sound about right?? I'm trying to get a ballpark idea in my head- of when it is that things start getting maxed out, not trying to be exact. Maybe I should ask when is the next size up recommended instead of asking when something "maxes out." Let me know what you more experienced guys think the above chart should look like. Im taking a shot in the dark here.
Old Oct 9, 2002 | 05:21 PM
tony1's Avatar
I've made 450whp with a 2.5" downpipe and flexpipe and tanabe racing medallion exhaust (2 3/8"). It's not so much the limits it's just extra restriction and you loose a little bit of power.
Old Oct 9, 2002 | 06:47 PM
mos's Avatar
mos
Default Re: anyone here got turbo n 2.25 inch piping? (tony1)
Ahh I think I get it now. Your post is encouraging since I've already got a 2.25 inch system. I'm planning to use a 2.5 downpipe/flexpipe with this.
Old Oct 10, 2002 | 02:54 AM
from what i know about turbo's, it should just stop you from reaching boost as fast as a big exhuast would. your turbo might not fully spool until 5-6K where normally it would be 3.5-4.5 K (just an example)
Old Oct 10, 2002 | 02:58 AM
Dramier's Avatar
3" downpipe to 3" all the way back, and it's not nearly as loud as I feared it would be. It has a slightly louder growl than stock, but it's not Flowmasters by far. In fact, my truck with 2.2L and glasspack is louder, and my wife's NA Z with 2.5" and high-flow muffler is louder.
I think it all depends on the muffler you go with more than anything else.. Turbo exhaust is typically quieter because of the turbo, or so I've been told.
fullthrottleking
Jul 31, 2008 08:41 PM
namm
Dec 21, 2006 10:07 AM
PIFFSTAR
Sep 21, 2004 01:16 PM
turbogsr13z
Sep 27, 2002 12:26 PM
Pengo
May 18, 2002 10:54 AM
