distributor trouble
car just seems to quit fireing at 25 in firstgear or 45 in second gear. i am getting 8 flashes at the ecu . the distributor looks new ... just got the car.. i replaced the ignition control module.the problem is intermittent
any suggestions
do i have to spend 500.00 to get a distributor that works?
any suggestions
**** no...i got my 89 crx si dizzy on ebay 129 dollars shipped to my front door, code 8 is the tdc signal i think, i cant remember right off, if it turns out to be the tdc signal your probably gonna need a dizzy, otherwise its in your harness which ive seen before
code 8 is tdc. I personally don't like distributors that aren't from honda unless it was dirt cheap. I have seen people on this forum practically giving away their old distributors. I would buy one of those.
Ohm the wires? what the hell? If you want to damage the ecu then go ahead. haha.
TDC a sensor inside the distributor that dictates when cylinder 1 is at top dead center. What is going on is when it gets hot the sensor tends to open. And just because the dizzy looks new doesn't mean its new.
How bout you try distributorking.com for the dizzy. Cuz that is your problem. Autozone dizzy are cool cuz they have a lifetime warranty.
