Jdm B16a swap, wont hold steady idle...help.
what up h-t,
i have a 1995 honda civic ex with a jdm b16a swap. my problem is my car wont hold a steady idle, idles goes up n down n the car wants turn off but sometimes then idles up n down going to a high idle then back to normal. it doesnt idle like that all the time tho, it only does it every now n then. i have checked all the vacuum lines n those r good, also clean the idle control valve so at this point idk what it could be, any info would be great. Thanks
I'm almost positive it would. It could be something else. But I would check the TPS. And your sure that the plugs aren't swapped for the MAP and TPS. They have the same plug and they are right next to each other. Cause it sounds like what happened with my swap, i just had them switched. As soon as I switched them back, i had a smooth idle.
on my swap, i had length either way. But, since you can't swap it, its probably in the right area. Are you throwing a CEL? If so, check the codes. But i would also suggest the TB Gasket.
No, no CEL. Car runs perfect no problems just idles weird every now n then but still annoying u know. Imma try to replace the throttle body gasket later today if i have time.
Thats the problem right there. You could find them aftermarket i believe. Its been a while since i looked for one. But I rememeber them going for like $20 online. If you go to the dealer, I can see them charging you an arm for it.
i actually just checked autozone online n they only go for 45$ so i think imma go pick one up n throttle body gasket while im at it.
Wow you got great timing, Im having the same issue. I did all the same things you did, but I went ahead and replaced the coil. But still acting up, and your right its annoying. Well G/L and keep us informed.
what n what have u replced so far on yours? n i'll let u know if mine gets fixed with the new TPS just gotta wait for it to come in the mail.
well I cleaned the IACV, and throttle body, PCV. Replaced the coil and roter, but kept the cap and wires. I cleaned and regaped the plugs back to .044. and put in a larger fuel pump. and checked all the wires to be in the proper place.
All this did clear up the a few small issue but still the idle will drop down from 800rpm to 300 then back up to 800 and hold.
