Jdm B16a swap, wont hold steady idle...help.
what up h-t,
i have a 1995 honda civic ex with a jdm b16a swap. my problem is my car wont hold a steady idle, idles goes up n down n the car wants turn off but sometimes then idles up n down going to a high idle then back to normal. it doesnt idle like that all the time tho, it only does it every now n then. i have checked all the vacuum lines n those r good, also clean the idle control valve so at this point idk what it could be, any info would be great. Thanks:thumbup: |
Re: Jdm B16a swap, wont hold steady idle...help.
bump! 37 views n nothing
is the MAP and TPS switched?
Originally Posted by hondaluver19
(Post 45458620)
Originally Posted by jceron64
(Post 45459061)
No, the map n tps r good, the map sensor is actually brand new. would the tps make it idle like that?
(Post 45459249)
I'm almost positive it would. It could be something else. But I would check the TPS. And your sure that the plugs aren't swapped for the MAP and TPS. They have the same plug and they are right next to each other. Cause it sounds like what happened with my swap, i just had them switched. As soon as I switched them back, i had a smooth idle.
It could be the throttle body. Gasket mite not be good. I had the same problem.
(Post 45459401)
I will recheck n switch the plugs to see if that helps the idle n i will let u know how it goes, thanks for helping out.
(Post 45459467)
good luck.
I actually just went to my car right now really quick n ur right that the switches the same so i tried switching them but the harness plug that goes into the TPS isnt long enough to reach up to the MAP so im guessing that they are plugged in right? |
Originally Posted by jdmslut27
(Post 45459426)
(Post 45459478)
but it does sound like a bad TPS sensor. I see alot of these broken on swapped motors.
(Post 45459501)
on my swap, i had length either way. But, since you can't swap it, its probably in the right area. Are you throwing a CEL? If so, check the codes. But i would also suggest the TB Gasket.
(Post 45459520)
(Post 45459565)
The TPS is actually kinda loose, looks like it was gonna brake. imma try to replace it but its gonna cost a good penny.
(Post 45459584)
Thats the problem right there. You could find them aftermarket i believe. Its been a while since i looked for one. But I rememeber them going for like $20 online. If you go to the dealer, I can see them charging you an arm for it.
Autozone carries TPS sensors for about $46
cool. good luck man.
(Post 45459632)
TPS is $15-25 on ebay. Just get one if it looks like its partially broken.
Originally Posted by Jimster480
(Post 45459663)
(Post 45459663)
Wow you got great timing, Im having the same issue. I did all the same things you did, but I went ahead and replaced the coil. But still acting up, and your right its annoying. Well G/L and keep us informed.
Originally Posted by ek9_B18C
(Post 45463490)
what n what have u replced so far on yours? n i'll let u know if mine gets fixed with the new TPS just gotta wait for it to come in the mail. |
well I cleaned the IACV, and throttle body, PCV. Replaced the coil and roter, but kept the cap and wires. I cleaned and regaped the plugs back to .044. and put in a larger fuel pump. and checked all the wires to be in the proper place.
All this did clear up the a few small issue but still the idle will drop down from 800rpm to 300 then back up to 800 and hold. |
