93 dx d15b7 stock rev limiter???
i have a virgin p28 in it! was gonna go mini-me.but im pretty sure itll stop at about 5500. ill ty and upload a video of it today. could it be off if my speedometer is wacko?
its throwing the code for the vtec sensor and yes you could do a z6 head swap but its alot more than just slapping it on you would need to get a new timing belt and replace all gaskets you encounter pulling the old head off and you would also have to have your ecu chipped and tuned (something few people do on mini me builds) because the d15 pistons create higher compression than the z6... the easier route would be to just put a p06 ecu back in or get the p28 chipped to a p06
your probably hitting the cut becuase its a p28 and you dont have VTEC. I know some Virgin ECU's dont let you rev past the VTEC engagement point typically if VTEC doesnt engage. Because my friends CL had a issue with the solenoid and his would hit a "rev limiter" at about 5400 or so because of the VTEC.
well then your tach isnt off, so it is for sure hitting the limiter at the wrong RPM. Especiallly if you put it on a P28 and it doesnt hit the non-vtec cut, it should go to 7200RPM because thats the redline on a Z6.
Acura_I-RS
Oct 30, 2005 09:06 AM
