Timing belt question...
was that serious...
water pump should fit. timing belt should fit as well. the deck height is different on a B16 to a B18 but i'm sure it's not enough to make honda manufacture 2 different belts for basically the same motors. maybe the belt tensioner comes into play.
B16A2 T-belt: 14400-P2T-004
B18C1 T-belt: 14400-P72-014
The part numbers are different, but that doesn't always mean the parts are different. The reason I say it won't work is because I got a B16 belt for my friends GS-R. He took it to the dealer for installation, and they said it was too tight. Ended up ordering a C1 belt and had a day of down time.
I wouldn't try to use a B16 belt on a B18A/B because the deck is even taller.
IMO there is no sense in screwing around with this. Get the correct belt for the engine you've got OP.
zach1288
May 8, 2007 06:04 PM
