Em1 condenser fan problems! Help
Old Jun 11, 2011 | 12:25 AM
hotdoggies's Avatar
Default Em1 condenser fan problems! Help
So today i went to the races just to watch . A/c was cold the whole way in 100 degree temps. I come to a stop and after 20 sec or so a huge cloud of smoke comes out. Upon inspection i see that it was the pressure release valve releasing refridgerant. About this time i notice my condenser fan not turning a/c is on with the compressor engaged.
Drove home tonight and on the hwy its ice cold again. The fan is still not engaging. Coming to a dead stop i turn the a/c off just to be safe. So i figure....its the fan not turning on causing the refridgerant venting,from it not being properly cooled properly. On the hwy all is well.
Ok so if this sounds right can someone post a wire diagram/wire colors to test the fan and or the relay.
Suggestions welcome thanks guys.
Old Jun 11, 2011 | 04:09 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Em1 condenser fan problems! Help
It might help to list the car you have
Old Jun 11, 2011 | 11:05 AM
hotdoggies's Avatar
Em1 99-00 civic si. I though putting it in the thread title was enough.
Old Jun 11, 2011 | 11:23 AM
Technical Hero
Old Jun 11, 2011 | 11:40 AM
hotdoggies's Avatar
Before all this started i remember the fan rotating very slowly. I was thinking thats odd. So i see the power wire of the fan is white? Thanks for the diagram bro
Old Jun 11, 2011 | 12:26 PM
Technical Hero
I mean honestly what I would do is get a voltmeter and see if the fan is getting 12v with the A/C on (one wire will be power and one is ground). If it is the fan is bad. If it isn't start at the fuse and then check the relay.
Old Jun 11, 2011 | 12:56 PM
hotdoggies's Avatar
^^^ Thats what i was thinking. Maybe just do 12v source to power wire of the fan to see if it comes on. If it does then looks like a relay. Just to be sure the power wire of the fan is White correct? Also will all condenser fans from 96-00 civics work for this car? Any info appreciated
Old Jun 11, 2011 | 02:01 PM
Technical Hero
Yeah white
Old Jun 12, 2011 | 08:11 AM
hotdoggies's Avatar
Performed test it was a break in the wire
heisenbergtapia
Sep 7, 2016 01:58 PM
josemt
Jun 23, 2010 06:24 AM
toyonda
Dec 10, 2008 06:07 AM
