Electrical Problems
Old Dec 9, 2008 | 09:27 PM
toyonda's Avatar
Icon2 Electrical Problems
I would like to know what would cause my cooling fan, and a/c fan to stop working? when my car gets hot, the cooling fan still wouldn't come on by itself. When I switch on my a/c, my a/c fan never comes on. I would like a non-overheating car with proper a/c
Old Dec 10, 2008 | 04:40 AM
P_Adams's Avatar
First of the usual suspects:
Coolant fan switch
Second of the usual suspects would be:
Coolant fan relay
I would also suggest checking the viability of the fans themselves. It's not uncommon for a fan motor to give up as well.
P
Old Dec 10, 2008 | 05:17 AM
Duane_in_Japan's Avatar
You will have to start hot wiring things from the fans towards the control head, once you get to a certain point, the hot wire will not make the fan come on and you have found your problem.
I will try to find a schematic for you and post it here, no promise though.
Does the air cond compressor come on even though the fan does not? Look very closely at the underhood fuses, actually test them.
Do you know how to bypass a relay, do you have a test light or a multimeter?
Old Dec 10, 2008 | 05:53 AM
Sorry for the poor paste job, excuse the two overlaps.
Blow it up to 150%.
Here is a radiator fan control module link that may help. Post #9.
https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-lx-radiator-fan-problems-2444833/
File Type: doc
Old Dec 10, 2008 | 06:07 AM
pimpdd101's Avatar
check fuse. if thats fine
then check to see if your getting 12 volts to the fan with a dmm. if so and the fan dosent work its prolly the fan
Shinwasha
Feb 17, 2012 07:50 AM
jlowellintegra
May 30, 2011 07:52 AM
19 crx 89
10
Aug 26, 2010 12:38 PM
Jonathan_ED3
Sep 27, 2008 10:11 AM
Hybrid
May 18, 2002 12:52 PM
