Soft Clutch pedal
Old Jun 8, 2011 | 05:58 PM
hondaman991's Avatar
Default Soft Clutch pedal
My stupid car is at it again and at this point im sick to my stomach I replaced my Master cylinder because it was leaking inside the car so that's done and I've bled the living hell outta the clutch line and the pedal will get stiff but after driving it for a bit the damn thing goes back to being soft I don't think it the slave cylinder because I've check to see if it was leaking and it wasn't so I don't know what the hell to do. I wan't to get it fixed before I sell the car Its posted up for sale right now but I wanna make sure its in good condition before she goes.
Old Jun 8, 2011 | 06:02 PM
98civdx's Avatar
Master Detailer
Default Re: Soft Clutch pedal
How old/ how many miles are on the clutch?
Have you checked the line for any leaks?
Old Jan 1, 2014 | 06:45 PM
DC4_Lewi$'s Avatar
Was this ever resolved? im having the same problem!
Old Jan 1, 2014 | 07:12 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
How long did you bleed the line for? Maybe you didnt bleed it enough? How did you do it? Maybe you have a leak in the lines as 98civdx said? Have a friend help you bleed and inspect the lines as it may be a small hole...did the pedal get soft overnight?
Old Jan 2, 2014 | 04:15 AM
95Sedan's Avatar
i would check the line going to the res, my clamp was loose and caused a bad pedal. Also just replace the slave cylinder theyre 15$ or so anwyays.
Old Jan 2, 2014 | 04:35 AM
EsotericImage's Avatar
Retired Moderator
old thread bumped..
Im sure the OP fixed it by now.
Old May 11, 2020 | 06:57 AM
DLOWK's Avatar
Did you guys figure this problem out ?
my clutch isn’t getting any pressure no mater how much I bled it & ive only swapped the slave cylinder
I don’t see the master cylinder leaking from inside , is it possible for my throw out bearing to be bad & causing my clutch fork & my clutch pedal not getting any pressure ?
B_Swapped93
Dec 14, 2012 04:32 PM
jdm kidd
Jan 14, 2011 08:22 AM
ChenLung
Mar 12, 2010 04:09 AM
o0Riffraff0o
Aug 13, 2009 09:12 PM
kelvinchau25
Jan 17, 2008 08:34 AM
