Soft Clutch pedal
Soft Clutch pedal
My stupid car is at it again and at this point im sick to my stomach I replaced my Master cylinder because it was leaking inside the car so that's done and I've bled the living hell outta the clutch line and the pedal will get stiff but after driving it for a bit the damn thing goes back to being soft I don't think it the slave cylinder because I've check to see if it was leaking and it wasn't so I don't know what the hell to do. I wan't to get it fixed before I sell the car Its posted up for sale right now but I wanna make sure its in good condition before she goes.
Ferio Wdm Edition
Re: Soft Clutch pedal
How long did you bleed the line for? Maybe you didnt bleed it enough? How did you do it? Maybe you have a leak in the lines as 98civdx said? Have a friend help you bleed and inspect the lines as it may be a small hole...did the pedal get soft overnight?
Did you guys figure this problem out ?
my clutch isn’t getting any pressure no mater how much I bled it & ive only swapped the slave cylinder
I don’t see the master cylinder leaking from inside , is it possible for my throw out bearing to be bad & causing my clutch fork & my clutch pedal not getting any pressure ?
B_Swapped93
12-14-2012 04:32 PM
o0Riffraff0o
08-13-2009 09:12 PM
