Clutch Dead?
Clutch Dead?
My clutch pedal sticks when its in which i can pull out with my foot. it doesnt seem to have any pressure until its nearly completey at the bottom and then it catches right away. sometimes i cant even shift until ive pumped the pedal a lot. wuddup with that?
Re: Clutch Dead?
Check your master and slave cylinders to see if there's a leak. I had the same problem with my car last year and it ended up being the slave. It was an easy fix. If both of those seem to be ok, try bleeding the line and putting in fresh fluid. I would be willing to bet that it is the slave cylinder though. Good luck!
