Is a 12 ton hydraulic press sufficient?
Hi,
I have an EK Civic.
Will a 12 ton hydraulic press meet the demands of pressing out my suspension bushings (all of them) or should I go bigger?
This is what I'm looking at:
http://losangeles.craigslist.org/lac...424709357.html
Thanks!
I have an EK Civic.
Thanks!
Yes, the pressure is enough, but those designs are ****. It will take a 2 hour job and turn it into an 8 hour nightmare. You'll discover swear words you never knew existed.
I'm not sure 12 tons (at least in that design) is necessarily enough to remove seized bushings. I used a 20 ton press and it had some trouble on the LCA. You might need to do some burning/cutting.
12 is plenty for installation, though.
I just put a guide in the Integra forum describing how to replace bushings. You should check it out as most of the info in the guide will apply to you:
https://honda-tech.com/forums/acura-integra-6/faq-how-replace-rear-suspension-bushings-full-guide-2944576/
Good feed back. I think I'm going to play it safe and look for a 20 ton press
What is a better press design?
Thanks guys
Thanks guys
This doesn't utilize a press cylinder (like a jack) that sways back and forth as you try to steady it.
If you're going to use this often, here's my recommendation:
I have a 12-ton press just like the OP listed. I just used it last week to press out the UCA bushings on my Integra. Didn't have any issues.
UCA bushings are significantly easier to remove than LCA bushings. But I know some people have gotten LCA bushings out with the 12 ton press also. I also know some people haven't been able to :/
Of course, there are other ways to get the bushings out or to weaken them to make extraction easier.
I'm about to buy a 20 ton press and notice that a few have a sliding ram..which would seem a bonus - as long as the ram can be securely locked in place. Has anyone any experience of this specific type of press?
Thanks in anticipation
20 ton wouldn't budge my bushings. I ended up burning them out.
With that said, I did UCA bushings for my buddy with my 20 ton. Worked like a champ. I would try with the press, if it doesn't work burn them.
ive got one in my garage currently. with coupons it was like 150 bucks and i split it with 2 other friends. we have use it on anything from honda lca bushings and wheel bearings to balljoints on my full size truck to removing seized pins on a case backhoe.
Littleton
Oct 18, 2003 08:58 AM
