Lowering Question
Old Jun 7, 2011 | 10:28 PM
pmp's Avatar
pmp
Default Lowering Question
Hey, Im going with koni str t orange struts and lowerig springs which will be between 1.5-1.75 lowered. will i need a camber kit or will i be fine? I dont want to find out that my tires go bald. Thanks
Old Jun 7, 2011 | 10:36 PM
EJ1_CRIS_909's Avatar
Default Re: Lowering Question
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/It would be wise to post the year and model of your car when writing a post.
But you dont need a camber kit. Just get an alignment and you will be fine.
Old Jun 7, 2011 | 10:44 PM
pmp's Avatar
pmp
its a 98 civic
Old Jun 7, 2011 | 10:45 PM
pmp's Avatar
pmp
also should i replace the bump stops when im doing the struts 145k miles
Alignment after lowering is all that is needed. No camber kit is required.
Old Jun 7, 2011 | 10:46 PM
pmp's Avatar
pmp
ok whats a camber kit for then
Old Jun 7, 2011 | 10:54 PM
The main use of a camber kit is for track (autocross). It allows you to adjust the camber according to how you want it to feel and handle on the track.
But people who have low offset wheels also use em to allow their wheels to sit flush.
Here is a good post on why camber kits arent needed: https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
Old Jun 7, 2011 | 10:56 PM
usafdad120108's Avatar
I have mine dropped on function and form type 1's and its WAY lower than what yours will be. Trust me you wont need a camber kit. An alignment is all that is needed. I wish I had my paper of my alignment so I could show youo but im at work so Ill post it when I get home if I remember
Old Jun 7, 2011 | 10:59 PM
pmp's Avatar
pmp
ok, should i replace the bump stops there only 20 bucks for all 4. Car has 145k miles on it. What do you think? My friend is doing the work
Old Jun 7, 2011 | 11:04 PM
Same here, type 1's on my da lowered all the way without messing with preload. Had it like this for 2 months with no alignment so far and tires are still excellent.
It would be good to replace any worn out bushings to get an accurate alignment. If you go to a "Professional" alignment shop, they wont even do ur alignment unless all the worn bushings are replaced.
Old Jun 7, 2011 | 11:10 PM
pmp's Avatar
pmp
my friend is gonna do it at the shop he works at. what bushings are you talking about.
Old Jun 7, 2011 | 11:14 PM
There are the front LCA bushings, Ball joint bellows, tie rod ends could go bad, upper control arm bushings, etc.... Have it inspected first. If things need replacing, have ur friend replace em. Then take it back for the alignment.
Old Jun 7, 2011 | 11:19 PM
also im not sure of the name of it but alot of ppl have the bolts break on the bottom of the struts/ forks didnt happen to me but maybe i just got lucky just make sure you have some extras around just in case
Old Jun 7, 2011 | 11:27 PM
pmp's Avatar
pmp
the tie rods are good ive replace the inners with moog. the outters are still stock but ive checked the wheel off the ground and theres no movement. What about bump stops im not sure if thats considered a bushing.
Old Jun 7, 2011 | 11:28 PM
pmp's Avatar
pmp
usafdad what do you mean the bolts break on which strut the old or new?
Old Jun 7, 2011 | 11:31 PM
Ya bump stops too. It wouldnt hurt to replace em.
Old Jun 7, 2011 | 11:36 PM
pmp's Avatar
pmp
when the inner tie rods were dont nothing was mentioned about bushings or anything other then tie rod boots and the auto techer said the outter tie rods. I had him check everything for me
Old Jun 7, 2011 | 11:38 PM
pmp's Avatar
pmp
im looking at bump stops at carpartswholesale though and the bump stops have all different shapes it appears?
Old Jun 7, 2011 | 11:42 PM
when i bought my coilovers it didnt come with new bolts that mount it to the lca so I had to reuse my old ones....however I have heard that these are prown to seizing up and snapping when you try to take them off so be careful
Old Jun 7, 2011 | 11:50 PM
pmp's Avatar
pmp
ok whats lca stand for
Old Jun 7, 2011 | 11:52 PM
lower control arm. try searching alot of the forums for some good info, write-ups, and pics of other ppl and how they did the install. you will learn alot
Old Jun 7, 2011 | 11:54 PM
pmp's Avatar
pmp
ok, so you had to replace the whole control arm?
Old Jun 8, 2011 | 02:48 AM
no just the bolt if it breaks like i said is your best friend
Accord-Guy
Suspension & Brakes
May 12, 2010 03:29 AM
92integraVTECgsr
Suspension & Brakes
Jun 23, 2009 10:33 AM
siguy9900
16
May 13, 2008 07:05 PM
babes 99 GSR
Sep 25, 2003 10:29 AM
tr4il
Nov 23, 2001 10:14 AM
