Camber Kit...
Old Nov 21, 2001 | 08:40 PM
tr4il's Avatar
Default Camber Kit...
What is a camber kit and why is it needed? Do i need one if i get sportlines + 16's?
Old Nov 23, 2001 | 10:14 AM
L8apex's Avatar
Default Re: Camber Kit... (tr4il)
basically, camber kits let you adjust how far in the wheels tilt when you look at it from the front or back. with sportlines (approx. 2" drop?) you might need it because the wheels tilt farther in the more you lower the car. keeping that extra camber should give you better/more stable cornering but totally kill the inside edge of your tires. get an alignment to fix your toe if you don't want to buy a camber kit, then the wear wouldn't be as bad. a camber kit will let you bring your camber setting closer to factory spec.
Accord-Guy
Suspension & Brakes
May 12, 2010 03:29 AM
BJA86
11
Sep 2, 2007 01:00 PM
crx1009
Apr 5, 2006 09:57 AM
ramz7887
Mar 23, 2003 09:18 PM
silvlude
Mar 17, 2003 02:37 AM
