JDM B18C1 with white smoke at VTEC
Compression was perfect, 230 across
No loss of fluids that I can see
And new plugs were installed.
Possible idea: at VTEC the car runs richer, cause for smoke?
(((((( i got a 91 ls and lately its been smokin reallly bad blowing out white smoke and i don't know what it could be. I'm not losing any coolant, But i am burning a little bit of oil.????))))))
Sounds like headgasket
any over heating?
You can do a leak down to see if any air bubbles are coming out of radiator
Its Blowing Out White Smoke! Sometimes a lot of smoke and sometimes it doesn't even smoke, but i noticed something leaking, its two hoses that go under the intake manifold, its leaking green liquid which i think is coolant because it smells just like it. and no over heating what so ever
Yup thats coolant. Check coolant level. Low coolant can result in a warped head and a blown hg .
But sounds like hg, u should get the head resuranced because it probably warped
