car won't start, help needed
Old Jun 7, 2011 | 05:37 PM
Eg Fool's Avatar
Default car won't start, help needed
hey guys i own a 94 civic coupe. it has a jdm d15b in the car, but everything else is oem. i have been driving it with no issues but tried to start it this morning and it woult not start.
i hear no click so i tried to jump start it, that did no good and got the battery tested and the battery is perfectly fine. the starter was replaced around 5 months ago with a brand new one, at the same time as the battery.
everything powers up and works fine, but when i try to turn it over i hear no sounds. i can hear the fuel pump prime but that is about it. any suggestions? i'm at a loss at the moment.
Old Jun 7, 2011 | 07:09 PM
Former User's Avatar
Default Re: car won't start, help needed
The red arrow points to a rubber stopper that presses on the starter switch at the top of the clutch pedal. Did it fall out or break?
Old Jun 7, 2011 | 07:25 PM
95EG2's Avatar
try tapping on starter solenoid and get someone to turn key while u bang and see if it starts(i know u replaced the starter but the way u explain it could be a defective starter)
Old Jun 7, 2011 | 07:29 PM
Eg Fool's Avatar
about to check
Old Jun 7, 2011 | 07:30 PM
r_Senik's Avatar
do what ronj posted up.
Old Jun 7, 2011 | 07:38 PM
95EG2's Avatar
and check all fuses under hood and under dash
Old Jun 7, 2011 | 07:39 PM
Eg Fool's Avatar
that piece is missing, i pressed the clutch and button and had someone turn the key and it fired right up! thanks for the help man! any idea on how to get around this? i'm looking for things to shove through there right now
Old Jun 7, 2011 | 07:52 PM
Some people hot glue a penny over the hole.
Old Jun 7, 2011 | 07:54 PM
Eg Fool's Avatar
i've got a hot glue gun, and some change, time to get to work. thanks again! you guys really made my night
speedfreek128
Honda S2000
Mar 13, 2015 07:49 AM
ogshokka
Nov 8, 2010 09:46 AM
skinnyshugg
Sep 5, 2006 08:51 PM
Fatboy1985
Dec 26, 2003 02:38 AM
mingchi69
Jul 14, 2003 06:14 PM
