I feel like a idiot! 00 Civic EX cuts out
Old Jun 7, 2011 | 03:14 PM
crxjarred's Avatar
Default I feel like a idiot! 00 Civic EX cuts out
Ok to start i have a 00 ex coupe 5 speed. My problem is my car cuts out but the weard thing about it is just once and exactly the same time when my car is started. Ok every morning or say when i go park at a public place and i am going to be there for a little while and i shut my car off or say in the morning im starting it up for the first time of the day, but it will drive for about a 60 seconds and it will just drop the rpms all the way and sputter realy bad and if your on the gas it jerks and it makes me like like a ****en ricer ***get thats just romping on the gas becouse when you give it a little gas it will take off like a rocket as soon as what ever its doing stops and i have started to just push in the clutch to stop it as soon as i feel the power loss but i dont wana do that any more its starting to get old. To try and fix this i have put new plugs, wires, dizzy, i have good spark i changed the fuel filter and checked the fuel pressure and it was 10 over stock dont know why? but what could the freaken problem be i need help!! thanks.....
Old Jun 7, 2011 | 04:00 PM
EE2bitsk's Avatar
Default Re: I feel like a idiot!
check what code/s its throwing.
Old Jun 7, 2011 | 04:35 PM
civicStyle's Avatar
try a primary o2 sensor
can cause crazy things to happen, i have seen o2's go back and not throw a cel.
Old Jun 7, 2011 | 06:59 PM
Former User's Avatar
Default Re: I feel like a idiot! 00 Civic EX cuts out
Please create informative thread titles that reflect your tech question. Title edited.
Old Jun 8, 2011 | 03:04 PM
crxjarred's Avatar
Sorry about that I thought my car is cutting out is good but ok. Weard thing is no engine light. And with the O2 censor it only happens once and thats like a min after i start my car wouldnt a bad censor be an all the time problem?
Old Jun 8, 2011 | 04:02 PM
Bter_Civic's Avatar
Change your Throttle position sensor. It is located on the back of your throttle body. The sensor is riveted in, however you could find another throttle body probably fairly easy..craigslist..ebay. These sensors are dialed in and set from the factory. I believe you can dial one in with an ohm meter or something like that. I had the same problem, found a throttle body at a junkyard with sensors attached, installed, and problem fixed. Good luck fellow ricer
Old Jun 10, 2011 | 03:06 PM
crxjarred's Avatar
Im not a ricer but thanks for the info much appricated i think i have one layen around so ill check it hope it works!!!
ranamv619
Oct 6, 2014 08:49 AM
CivicGuy2014
Mar 24, 2014 10:05 AM
McMahon
May 29, 2012 12:01 PM
Got Snail 2
15
Nov 20, 2007 04:21 AM
vorovsky
16
Aug 3, 2003 12:59 PM
