obd2 to obd1 conversion no spark
Old Jun 6, 2011 | 05:55 PM
brownsEF's Avatar
Default obd2 to obd1 conversion no spark
alright so swapped in an h22 into my buddies 96 coupe dx the car starts with the stock ecu obd2 but when I use the jumper harness to obd1 with the p28 I get no spark any ideas?
Old Jun 6, 2011 | 06:16 PM
Former User's Avatar
Default Re: obd2 to obd1 conversion no spark
Bad P28?
Old Jun 6, 2011 | 07:16 PM
brownsEF's Avatar
or bad jumper harness that's what I'm thinking
Old Jun 6, 2011 | 07:28 PM
Quite possible.
Old Jun 7, 2011 | 02:43 AM
brownsEF's Avatar
ill try the ecu on another car tommorow
Old Aug 4, 2021 | 05:10 PM
Rio22's Avatar
hi I’m having the same problem did u solve ur problem was it bad p28 or the conversion harness pls help me out thanks
Old Aug 4, 2021 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It is one or the other... so try and eliminate one and then you know what the problem is in your case. Either try another ECU or try your current ECU is a friends Honda... if it works, then you know the harness adapter is the problem. If the ECU does the same thing in another car, or you try a "known good" ECU in your car, and it works... then you know the ECU is the problem.
novaslean
Apr 14, 2010 09:23 AM
mitchell_2kSiR
May 23, 2008 01:49 PM
egbaby
Mar 1, 2008 06:52 AM
spool310
Sep 6, 2006 10:02 AM
shawnc21
Jan 9, 2003 11:21 AM
