EG hatch/B16A swap/JDM P30 ECU - TPS & KS codes
Old Jun 5, 2011 | 08:39 PM
Dave1980's Avatar
Default EG hatch/B16A swap/JDM P30 ECU - TPS & KS codes
Ive searched and cant seem to find what I need. I have a B16A 2nd gen in my EG hatch. Im getting a TPS code and KS code. Not sure if theres a sensor there or not to be honest. Im using a harness out of a 95 GS-R and a JDM P30 ecu. For one im trying to figure out what 2 plugs on the harness go to. One im assuming is the knock sensor but the other is closer to the distributor.
The AC and power steering are not in the vehicle. Could one be for the AC?. Also the oil pressure or temp sensor next to the filter (looks like a metal nipple coming off it) Is there supposed to be a plug on there?. There isnt and I wasnt sure.
Im new to motor swaps and this is my first so im not sure what to do here.
Also while im asking questions, what would cause a clutch to sometimes catch slightly towards the floor but catch the rest of the way up further?. Slave cylinder not bled properly?.
Old Jun 5, 2011 | 08:46 PM
ricky00's Avatar
Default Re: Could use some help with some sensors
green plug is ur oil temp sensor and the knock sensor goes right nest to the oil temp sensor
Old Jun 5, 2011 | 08:57 PM
Dave1980's Avatar
Does anything plug onto the oil temp sensor though?
Old Jun 5, 2011 | 09:05 PM
ricky00's Avatar
yes it does... should be a black rubber plug
Old Jun 5, 2011 | 09:21 PM
Raven2201's Avatar
Is it a actual plug coming from the harness?.
FYI this is my account, I posted this thread through facebook since I couldnt remember my login info.
Old Jun 5, 2011 | 09:26 PM
ricky00's Avatar
yes it is.. it should be next to the altnator sensors
Old Jun 5, 2011 | 09:39 PM
ricky00's Avatar
its the left most round black plug
Old Jun 5, 2011 | 09:41 PM
Raven2201's Avatar
Is it a yellow wire with a stripe?. If so im guessing its the wire that someone cut
Also the knock sensor is there and plugged in. Wondering if maybe theres nothing in the slot at the ecu or something.....damn this is confusin me.
Old Jun 6, 2011 | 06:53 AM
Raven2201's Avatar
Ok so I wired my knock sensor today and now it idles lower for some reason. When I step on the gas it drops idle and seems like it wants to stall. Not sure why its doing this. I wired it to pin D3 on the ECU.
Old Jun 6, 2011 | 09:59 PM
Raven2201's Avatar
Default Re: EG hatch/B16A swap/JDM P30 ECU - TPS & KS codes
up.....
c0d0r
Feb 14, 2009 07:38 AM
tial-eg
15
Jun 13, 2006 11:13 PM
arkady187
May 9, 2004 11:45 AM
littlecrxVTEC
Dec 20, 2003 03:41 PM
T_Rex
10
Sep 10, 2002 08:38 PM
