88 hf wont start
Old Jun 4, 2011 | 11:39 AM
Klean88Si's Avatar
Default 88 hf wont start
I bought this hf for 550 a couple of months ago as a project. Two days ago I was driving and it just shut off on me. I check and replaced the spark plugs and wires. Checked the main relay, The problem is itll crank all day but wont turn over the timing belt isnt bad so idk why. any Ideas???? I know its a pos d15b6 but still id like for it to run until my swap b16a comes in..
Old Jun 4, 2011 | 12:13 PM
josephcmiller2's Avatar
Default Re: 88 hf wont start
I will buy it for $350 since you broke it.
Old Jun 4, 2011 | 12:31 PM
Klean88Si's Avatar
No thanks lol.
Old Jun 4, 2011 | 01:11 PM
Navy_Kyle's Avatar
check fuel spark and compression
Old Jun 4, 2011 | 05:24 PM
Originally Posted by Klean88Si
No thanks lol.
Worth a shot, you never know, haha.
Yeah, check for spark first because it's the easiest. Put a used plug on one of the wires and touch it to a ground. Have someone crank the car and see if you can see the spark.
If no spark, then something is wrong at the dizzy.
If yes spark, pull the distributor cap and check the rotor button. Make sure the rotor button is tight to the shaft and looks to be in good condition.
Then disconnect the distributor connectors. Rotate the crankshaft and make sure that the distributor turns.
All of that should just about completely cover any spark issue that would cause you to go from running to not running. Try that stuff and then let us know.
Old Jun 4, 2011 | 11:49 PM
SOHCwarrior's Avatar
How did you "check" the main relay?
Old Jun 5, 2011 | 12:20 AM
efiliatedef9's Avatar
check if the timing jumped
gerbsgsr
15
Dec 28, 2015 08:46 PM
hondaboy90
24
Oct 29, 2006 06:38 PM
purplexs650d
Oct 17, 2006 12:31 PM
909ej195
Oct 9, 2006 08:31 PM
gLotex70
May 31, 2003 01:30 AM
