how to remove a pin on distributor shaft
Old Jun 1, 2011 | 09:24 PM
noltian's Avatar
Default how to remove a pin on distributor shaft
I have 2000 Accord SE and tried to replace inner seal and have no idea how to remove a pin from the shaft. It looks like I have to push it out but I couldn't do it by hitting with hammer or anything yet. I didn't use much force afraiding of bending or breaking something.
any help is appreciated. If I know how to add a photo, I wish to....here
Old Jun 2, 2011 | 07:58 AM
jamzx3's Avatar
Default Re: how to remove a pin on distributor shaft
here you go...its in the faq section...https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-internal-seal-distributor-internal-oil-leak-2214402/
Old Apr 16, 2012 | 11:37 AM
sa2ms7on's Avatar
He's talking about a different kind of set up. His has a pin that appears to be pressed in like mine. I'm trying to figure it out myself...
Old Apr 16, 2012 | 10:18 PM
mudpuppy4life's Avatar
talking about the pin holding the gear to the dist. shaft? on my 96 f22b2 i removed the pin with a center punch and a 3 pound mini sledge hammer. it popped out on the second or third tap
Old Apr 17, 2012 | 01:57 PM
Duaber's Avatar
I've got the same issue i've decided to give up today. As far as I can tell there are no washers/c-clips like the tutorial.
Old Apr 17, 2012 | 03:48 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
I answered your PM ^^^.
I have never come across this issue, therefore I am stumped
Old Apr 17, 2012 | 06:31 PM
center punch and a hammer dont beat on it just let the weight of the hammer do the work and it should walk right on out
Old Apr 23, 2012 | 07:40 PM
sa2ms7on's Avatar
Did you hold it in a vice or anything?
Old Nov 29, 2016 | 08:27 PM
coolguy001's Avatar
This may be too late for for the original poster. But for any one attempting this. I dd the following to get the pin out.
Hold the rotor in a vice. You may have to use a pipe on the vice rod to get this part super tight in the jaws of the vice. You will know it is not tight enough, if this starts sliding. This is very important. This part is super strong and should not break even on tightening this with a vice. Do not blame me if this breaks though.....
Next use a pin punch 5/32 will only fit on one side. So hammer the pin out towards that hole. Use a smaller size pin punch. Hammer away. It took me a good 1-1/2 hours to get the pin out. Changing the seal ring took less than 5 minutes.
Hammering the pin back in took a good 1 hour.
By the time I was done the pin punch end was getting flatter and spread out. I used a craftsman pin punch made in USA from Sears.
I really do not know why this distributor was designed this way. After fixing this I cleaned up all the oil leaks around the engine (which had been happening due to this leaking seal over the last few years, of course I did not realize this till the oil leak stopped)!
2accrds
Apr 7, 2017 08:15 PM
Zalitore
Jun 21, 2007 07:27 AM
Ideal
Oct 13, 2005 04:36 AM
pelotudo
Feb 19, 2002 03:03 PM
