No Turn Signals or Dash Lights
Old Jun 1, 2011 | 05:24 PM
BoostedAccord95's Avatar
Default No Turn Signals or Dash Lights
I got a 94 hatch cx no dash lights turn signals no noise form signals no hazzerds... It has a 95 integra cluster in it with that dimmer switch in i tried to run red to black off the dimmer and still no lights its not fuses so ANYHELP PLAESE thanks
Old Jun 1, 2011 | 06:12 PM
Former User's Avatar
Default Re: No Turn Signals or Dash Lights
Do the hazard lights work?
Old Jun 1, 2011 | 09:06 PM
No Sir...
Old Jun 1, 2011 | 09:15 PM
Make sure the connector at the rear of the hazard switch is plugged in.
Old Jun 1, 2011 | 09:17 PM
I Have But Was Plugged in... When u turn it on only the left turn light comes on but dont blink...
Old Jun 1, 2011 | 09:23 PM
Tis time to dust off your handy dandy multimeter:
Old Jun 1, 2011 | 09:25 PM
So am I Just Cleaning the relay or how do i test it???
Old Jun 1, 2011 | 09:44 PM
Well Nvm I see what your sayin just dont under stand the relay test..
Old Jun 1, 2011 | 09:45 PM
And I dont have a dmm handy...
Old Jun 1, 2011 | 09:58 PM
that_boy_sammy's Avatar
Since you do not have a multimeter have you checked all of your "instrument panel" fuses? If all of those are good it is most likely the dimmer switch that has shorted out, no way of fixing it so get a new one or one from the junk yard. I once had the problem that none of my panel lights or cluster lights were working, turned out to be the dimmer switch. Turn signals are a different problem.
Old Jun 2, 2011 | 05:34 AM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/why-dont-you-have-multimeter-your-tool-box-2915627/
The first diagram does not test the relay. It shows input tests for the relay socket. The results of the tests will help you pinpoint the problem.
The second diagram shows how to test the hazard switch.
Old Jun 3, 2011 | 07:13 AM
All Fuses Checked out Good And Like I Said It has A Integra Cluster with the integra dimmer swith is there a way to wire the teg switch to the civic swith???
Old Jun 3, 2011 | 07:15 AM
https://honda-tech.com/forums/showthread.php?t=2915627
Oh Ok Well I guess I just dont understand the 1st diagram
Old Jun 3, 2011 | 09:18 PM
You Guys Kno How To Make the turn signals work like any way
Old Jun 4, 2011 | 07:26 AM
Be more specific. What don't you understand?
Old Jun 4, 2011 | 01:52 PM
Connecting R or L to B or L those all them steps really
Old Jun 4, 2011 | 06:40 PM
Do you have a digital multimeter?
Old Jun 5, 2011 | 10:21 AM
My Buddy Does
Old Jun 5, 2011 | 10:46 AM
When you have it, post a picture of it and the probe leads.
Old Jun 5, 2011 | 02:18 PM
CivicBlacksheep's Avatar
10 Year Member
Icon2 Re: No Turn Signals or Dash Lights
Where do you get these diagrams from?
Old Jun 5, 2011 | 02:21 PM
Civic service manual.
cgjarvis
10
Aug 7, 2016 12:22 PM
akacoke
15
Sep 22, 2011 05:21 PM
TwoKSiR
May 19, 2009 10:13 AM
TwoKSiR
May 11, 2009 06:02 AM
