No Turn Signals or Dash Lights
I got a 94 hatch cx no dash lights turn signals no noise form signals no hazzerds... It has a 95 integra cluster in it with that dimmer switch in i tried to run red to black off the dimmer and still no lights its not fuses so ANYHELP PLAESE thanks
Re: No Turn Signals or Dash Lights
Since you do not have a multimeter have you checked all of your "instrument panel" fuses? If all of those are good it is most likely the dimmer switch that has shorted out, no way of fixing it so get a new one or one from the junk yard. I once had the problem that none of my panel lights or cluster lights were working, turned out to be the dimmer switch. Turn signals are a different problem.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/why-dont-you-have-multimeter-your-tool-box-2915627/
The first diagram does not test the relay. It shows input tests for the relay socket. The results of the tests will help you pinpoint the problem.
The second diagram shows how to test the hazard switch.
https://honda-tech.com/forums/showthread.php?t=2915627
cgjarvis
10
08-07-2016 12:22 PM
akacoke
15
09-22-2011 05:21 PM
TwoKSiR
05-19-2009 10:13 AM
TwoKSiR
05-11-2009 06:02 AM
